MTC3
#902
Are you not keeping the posts long while you fit the body, and determining the length after you've placed the body down over the posts? (I have the Hyrax body too, but I have not started working on it.)
#905
R/C Tech Elite Member
I took a pretty good hit on asphalt and it bent the Ti but the piece survived.
My second car I took a hit on the opposite and did the same thing.
I chose to use the Ti screws there instead of steel to save the part vs the screw.
#906
Martin Paradis
#908
I usually use the process on the the Twister Sp. So, this was the first time on the Hyrax.
First, I lay in the axle line which goes up and over the wheel wells and across the hood
In the picture below, I used the grid on my cutting mat to define two points I can use to draw the axle line on the hood.
Once the axle line is drawn, I can find its center using a reference (I'm using the seam lines)
Half of that is the center.
I create another line using the seams as a reference, and find the center of that line.
The Hyrax has a convenient bump in the center of the hood. We can draw a line from that to our center point.
From the axle line to the body posts is 50mm (caster and two can affect thiss.
I draw the body post line through the 50mm mark. The body post holes will be on this line.
I made a template that I can overlay over the body post line. it makes it easier to mark the drill points. Without it, I would simply extend my body post line further and mark drill points 44mm off the center line in both directions. (Again, that based on how my body posts are installed. there is an 88mm configuration and 76mm configuration)
Arrows mark the drill points.
#910
#911
Speciale Templates
That's the Fusion file for the templates. The file may be a little messy, I'm not a professional... yet. I made the templates specifically for the Speciale body because that's what I always run, but it may have other utility The goal was to be able to put body support and spoiler holes where they should be without having to touch the car. The marking holes are small because I use a felt tip pin to mark my holes--aim small, miss small. But I'm hoping that with the Fusion file anyone can make whatever adjustments they want.
The tracer block holds a typical sharpie at 8, 9, 10, or 11mm, and the hole is tapered so the marker only goes in one way.
The spoiler template kind of locks over the body's spoiler humps. It can be turned over to put matching holes in the spoiler itself.
The rear template is for making holes for the screws if] you are using the Mugen rear body clips. I don't have a template for running the body posts out of the rear of the car (yet).
The front template is 88mm, and if used on the Twister, and it is centered on the hood and the long end is put 3mm under the windshield seam, it marks exactly where the front body post holes go.
The wheel well template center is at 31.125mm high--the height of the axel when there is weight on the tire.
note: The hole templates don't account for body placement tuning (ie, more forward, or rearward, higher, or lower.) And as always, if in doubt, don't make a hole.
The standard "well it worked for me" disclaimer:
#913
My original car I used the Mugen Ti screws there to the bulkhead.
#914
#915
I just bought an MTC-3 and we'll be starting the build soon. I saw on a well-known store's website that they sell a MU-A2552 Mugen Seiki MTC-3 Bypass Damper Body kit, and my question is, what's the difference between this and the A2551 that comes in the stock kit?
780Likes
