Like Tree780Likes
MTC3
Old 10-27-2025 | 10:18 AM
  #751
lbckevin's Avatar
Originally Posted by Colby P
Hey guys, can you post some pics of where you have your weights set up to get the car to the limit weight of 1,320 please? 1up has his series at 1,350 so any tips and pics would be awesome. Thank you.
LOW ET likes this.
lbckevin is offline
Old 10-27-2025 | 11:00 AM
  #752
racing_jason likes this.
archivist is offline
Old 10-31-2025 | 11:25 AM
  #753
Thank you guys i appreciate the pics
Colby P is offline
Old 11-08-2025 | 07:07 AM
  #754
lbsnoopy's Avatar
Default Steel chassis
The weirc steel chassis is real nice , machining looks to be excellent imo.
lbsnoopy is offline
Old 11-11-2025 | 06:16 PM
  #755
What does the KPA arms do?
nitrodude is offline
Old 11-11-2025 | 09:33 PM
  #756
It changes the king pin angle.
The king pin angle is the angle formed where the ground line (horizontal) and the line that passes through the ball joins on the steering knuckles meet. The Inclined KPA arms move the upper ball joints of the steering knuckles inward, toward the chassis. Because of this, installing the IKPA arms will immediately introduce positive camber (top of wheels pointing outward from chassis), and some toe out.
With the upper ball links moved inward, the geometry of the suspension is changed--the upper suspension links will be shorter. The shortened links will introduce more camber gain during suspension compression (compared to the camber gain introduced with standard/typical upper link lengths.).
Old 11-11-2025 | 11:47 PM
  #757
Me too! Me too!!
Old 11-11-2025 | 11:57 PM
  #758
New kits come with the optional black tie rods as standard
Fastfreddy74 is offline
Old 11-12-2025 | 03:54 AM
  #759
R/C Tech Elite Member
Two good videos that talk about Caster and KPI
(at the 7:15 mark he puts scales on the tires and you can see load changes.)
Its may not be something for all tracks though but its an easy change to try.
Track grip plays a big part as well as a stable rear end.
Robbob is online now
Old 11-12-2025 | 09:16 AM
  #760
Originally Posted by archivist
Me too! Me too!!
And this was WITHOUT running the IKPA arms!!
Old 11-12-2025 | 09:27 AM
  #761
bmwjoon's Avatar
Suspension tuning is so blended. Yes you get more camber gain in compression because the top arm is shorter but the KPI changes the camber curve (with steering input) and also the scrub radius. So if you need a tuning item, typically more steering while the car is turning and or on power, increasing the KPI might do that while keeping most of your dynamics similar everywhere else. Mind you this is assuming you correct the static camber after changing KPI.
Robbob, archivist and h2e like this.
bmwjoon is offline
Old 11-12-2025 | 08:24 PM
  #762
StickyFingaz's Avatar
Is everyone running the body mount brackets that attach to the wing mounts or can I just drill holes in the rear bumper and forego them like a normal human being? I have a few bodies I plan on rotating/testing (practice, race, speciale vs regular etc) and don't want to have to buy a ton of body mount kits or take them off and on all the time. Also watched my buddy comically try to put the clips on and off from under and it was not selling it lol. You guys getting more planted rear ends with that thing?
StickyFingaz is offline
Old 11-12-2025 | 09:48 PM
  #763
So far, I am. I know it's risky business, but I don't usually put body pins on mine, especially in practice. When I do, it was awkward at first, but that's how it goes for anything new. I can install/remove pins pretty gracefully now.
Old 11-13-2025 | 03:58 AM
  #764
The only pros about the mounting brackets is you can tune body height as needed, while with holes you are stuck at where you drill em, I think they would be a performance advantage only if you are running mod on a large track.
So far I didn't bother yet about the mounting brackets
Old 11-13-2025 | 09:25 AM
  #765
I have found that it prevents tearing the rear holes on very thin body shells during crashes. Makes it a little more durable in my view.
Martin Paradis
dawgmeat and racing_jason like this.
rhodopsine is offline
