MTC3
#782
R/C Tech Elite Member
It fit perfect with out rubbing on the servo mount.
https://www.discountrcstore.com/schu...rvo-saver.html
#783
#784
Edit - Looks like actually 15 and 19, I was half a mm off with my eyecrometer and calipers!
#788
For me what I found was the car felt really "floaty". That sensation is really just a rear end just never really sets after you have all this weight transfer near the center. Also indoors with the amount of traction, it's the relation of grip to the front. So as the car transitions throughout the turn, the front continues a rate of rotation at a higher curve to the rear. You could probably tune this out with more front tuning and maybe more front glueing. Or maybe a harder progressive rear / softer front spring.
I bet guys that run outdoors have more success using the bypass or progressives in the rear.
#790
#791
#792
Thanks Bob! The Hiro Seiko spurs should fit as well and they are pretty good. The teeth are a little wider for those running. modified.
EA
#793
Is anyone else getting a sort of 'sprung' binding in the steering arm when tightening the highlighted screws (particularly the 2x6).
What I mean by 'sprung' is that after the 2x6 is tightened, the arm moves freely for a portion of its travel and then binds. Then when I push it to get past the binding, the arm suddenly flips the rest of the way... I guess it's like a light switch. You move it to a certain point, and then it will snap the rest of the way. My steering arm is doing something like that when I tighten 2x6.
#794
780Likes
