Like Tree780Likes
MTC3
Old 10-16-2025 | 02:11 PM
  #736
bmwjoon's Avatar
I don't like whatever alloy Mugen uses for the turnbuckles. As they break I use an aftermarket turnbuckle but in theory, if that doesn't break, something else probably will.
lbckevin likes this.
bmwjoon is offline
Old 10-16-2025 | 02:13 PM
  #737
gigaplex's Avatar
Originally Posted by mbunker
First broken parts. Wasn't a hard crash, I brushed the wall on the straight with my tire turned.
parts.
Aluminium turnbuckles do tend to fail when you snag a wall at speed.
dawgmeat likes this.
gigaplex is offline
Old 10-16-2025 | 04:53 PM
  #738
Yeah, any turnbuckle!
bigdog is offline
Old 10-16-2025 | 07:21 PM
  #739
STLNLST's Avatar
I’ve only bent the turn buckle but I’m sure if I ran the main in the class they would have finished me off.
STLNLST is offline
Old 10-16-2025 | 09:04 PM
  #740
disaster999's Avatar
Regional Moderator
Originally Posted by glennhl
I'd be curious that when your friend switched to the carbon chassis, did he add weight so that it was legal? I know I've switched to carbon and gone faster but then added weight and went a little slower.
I think he just did a straight up chassis swap so no, dont think he added weight back in to compensate but knowing him, his cars arent right at the weight limit so should still be legal
glennhl likes this.
disaster999 is offline
Old 10-18-2025 | 02:00 PM
  #741
oldernoob's Avatar
Originally Posted by bigragu
Your down stop screw is buried you need to back that all the way out and reset it that why your having trouble
No kidding, i started the outdoor season with those set too far down. I wondered why the car would spin out mid corner, tried all sorts to fix it - the arm was hitting the upstop, suspension could travel no further and said 'goodbye'. backed them off and it transformed the handling so i could get on with driving the car!
oldernoob is offline
Old 10-19-2025 | 12:32 PM
  #742
What are you guys doing to prevent the up-stop grub screws to the lower arms? (Or are you about that not-worrying-about-it life?)
archivist is offline
Old 10-19-2025 | 10:27 PM
  #743
Francis M.'s Avatar
I don't use it at all
Francis M. is offline
Old 10-20-2025 | 10:13 AM
  #744
So far, I just set them to where the chassis is juuuust about to bottom out, but in an accident, they can still gouge apparently.
Old 10-20-2025 | 11:17 AM
  #745
Marcos.J's Avatar
Super Moderator
Marcos.J is offline
Old 10-20-2025 | 10:04 PM
  #746
StickyFingaz's Avatar
Piecing my package together and my buddy is telling me this thing doesn't come with a spur gear. What are my options for 21.5 but 48p? Only slow classes being run near me unfortunately. I have trauma from stripping many many 64 pitch gears, so i'd rather not. Was trying to go as low as the low 60s, but i'm only seeing Kimbough making stuff like that and my understanding is the pattern is not compatible. Will the eXcelerate drag race spur work (whatever that means)? They make something as small as 66 tooth. Thx for the insight peepz.
StickyFingaz is offline
Old 10-21-2025 | 11:34 AM
  #747
For 48p you would need a ~60 tooth spur gear, RW racing black series for Xray fit nicely on the MTC3 and they make pretty small 48p spurs
https://rwracing.co.uk
Fastfreddy74 is offline
Old 10-21-2025 | 12:52 PM
  #748
I run USGT with 48p gears. I run a 66t Kimbrough/Associated along with a 42 tooth pinion.
https://www.amainhobbies.com/team-as...BoCAZ0QAvD_BwE
glennhl is online now
Old 10-27-2025 | 10:03 AM
  #749
Hey guys, can you post some pics of where you have your weights set up to get the car to the limit weight of 1,320 please? 1up has his series at 1,350 so any tips and pics would be awesome. Thank you.
racing_jason likes this.
Colby P is offline
Old 10-27-2025 | 10:14 AM
  #750
STLNLST's Avatar
1350…..you racing USGT?
STLNLST is offline
