MTC3
#872
Martin Paradis
#876
I run 50-60 grams extra weight to get to 1320
i automatically use the 20 gram weight under the receiver then run 15 grams front center, and 15 grams rear center. This is using short protei servo.
hw speedo, r1 v30 17.5. And protek 7400 2s lipo
#878
Martin Paradis
#879
My guess is that this is a typo.
32.2 instead of 22.2 and 32.0 instead of 22.0. (~ radius of common tire diameters 62-64 mm).
Popular upstop measurements are 14.6 mm but measured under the lower ball of the hub, which equates to ~32 mm when measured to the middle of the axle.
#880
Popular upstop measurements are 14.6 mm but measured under the lower ball of the hub, which is equates to ~32 mm when measured to the middle of the axle.
Martin Paradis
#881
For upstop, I followed how Jacob Cruz posted on Facebook and measure with shocks removed and chassis deck flat on the setup board.
In his video he showed how Volker measures and it came out to like the 14.x number.
#882
Downstop I use the 10mm blocks that came with my PowerHobby gauge (similar to Aerox).
Don't get me wrong, everyone can measure it however they want, but it's quite confusing when the information is not mentioned somewhere on it.
#883
So it's not a typo but you have to add 10mm to the measurement in your setup-sheet to get the real value that the drawing in the sheet shows.
UPDATE .... I updated my setup sheet above with additional notes.
rhodopsine please delete your quote as it still has the old screenshot
#884
While I don’t use these setup sheets, I always thought that the number actually recorded should be the distance indicated in the drawing (e.g., bottom of chassis to axle center or bottom link, as indicated)
Or does that not work?
#885
Like you said, it would be easier to use the real upstop values like it is intended, to spot differences in setups at first glance, without the need to study the notes on the setup sheet.
780Likes
