Like Tree780Likes
MTC3
Old 01-01-2026 | 06:37 AM
  #856
rcfiend's Avatar
Originally Posted by gigaplex
96/24 should get you started
Yeah that doesn’t work either. The motor doesn’t move forward enough for a proper gear mesh.
rcfiend is offline
Old 01-01-2026 | 09:55 AM
  #857
Originally Posted by dawgmeat
Getting zero rebound on these shocks are a PITA
Really?
I don't have any issues with building the shocks without rebound.
IMO they are super easy to build compared to shocks a few years ago.
Like I and some others mentioned you could try the Schumacher MI9 membranes, they are a direct fit and a lot more flexible than the original and revised mugen ones, that should help.
This is how i build mine: (Shock shaft length 7.5mm like in the manual)
1. Fill shocks up until the groove starts where the membrane sits. A bit more is okay, less i wouldn't recommend (Piston in the lowest position)
2. Lay the membrane into the oil bed, either from above or slide it into position from the side.
3. Massage the membrane with a 2.5mm ball hex into the intended groove. Pushing only in the middle part of the membrane.
4. Continue to massage the middle of the membrane while pushing the shock body down, or the shock shaft up until i feel the shock shaft with the hex driver.
5. Now, maybe max. 0.5 mm of the shock shaft should be visible
6. Remove excess oil on the upper edge of the shockbody or ontop of the membrane carefully with a microfibre towel.
7. Close the shock with the shock cap.
I've built my shock now ~30 times and only had 2 times air inside or more than 1 mm rebound.
Tomillia is offline
Old 01-01-2026 | 10:36 AM
  #858
Which motor are you using?
I had similar issues when running a 5.0 gear ration (90t spur / 34t pinion) on some motors.
On Hobbywing motors it is not a issue, but for example with an ORCA Motor the screwhead, which holds the Motor-Can together, intefered with the motor mount near the upper motor mount screw.
On another motor the chamfer on the motor case was too small and interfered with the chamfer on the motor mount.
In both situation i used a dremel and removed material from the motor-case / screwhead to make it fit.
gigaplex likes this.
Tomillia is offline
Old 01-01-2026 | 03:03 PM
  #859
On the original motor mount the largest I could fit was 90 spur (even when raised to highest position). Am I missing something or need the new motor mount?
rccartips is offline
Old 01-01-2026 | 04:34 PM
  #860
gigaplex's Avatar
What was preventing it? The manual says a 96 fits.
gigaplex is offline
Old 01-01-2026 | 10:31 PM
  #861
rcfiend's Avatar
I'm using a Hobbywing 5.5. I'll take a look and see if there's any interference from the motor can. Thanks for the feedback.
rcfiend is offline
Old 01-03-2026 | 03:55 PM
  #862
Hey guys,
Got a 3D printer for Christmas and having a little fun with it. I created a set of body mount spacers in various thickness for the MTC3 (3.0, 2.5, 2.0, 1.5 and 1.0). Here's the file for those of you who want to try it. Feel free to modify them as needed as long as you share it after. They're not perfect, but work fine with my twister bodies.
Martin Paradis
File Type: zip
rhodopsine is offline
Old 01-04-2026 | 07:22 PM
  #863
rcfiend's Avatar
Anyone know when kits and parts will be available?
rcfiend is offline
Old 01-06-2026 | 08:35 AM
  #864
any day now. They are either on a boat or waiting to go through customs.
Mig89 is online now
Old 01-06-2026 | 11:37 AM
  #865
MTC3's be like..
archivist is offline
Old 01-07-2026 | 01:11 AM
  #866
Nuno Gancho's Avatar
Hello any idea what the shims are for?
Nuno Gancho is offline
Old 01-07-2026 | 03:51 AM
  #867
These are probably the O-Rings that hold the pin in place, that drives the hex, not shims.
Tomillia is offline
Old 01-07-2026 | 04:22 AM
  #868
R/C Tech Elite Member
They're crush spacers for the bearing races - put them on the axle then the hex then the wheel.
Robbob is offline
Old 01-07-2026 | 05:13 AM
  #869
Ahh, you are right. Sorry, my fault.
I only looked up the manual and saw a different part number, thats why i thought it must be the o-rings then.
After you mentioned it, when i looked up A2251 in different shops no part appears.
Still feels weird that you can't buy the crush spacers separate and are only bundled with the hexes, despite their own partnumber. Makes no sense to me
Tomillia is offline
Old 01-07-2026 | 07:31 AM
  #870
Yes, that's a real pain. We also lost one of the spacers and are forced to buy the hexes. I then used several thin shims instead of the 1.1mm spacer. Works very well too.But it's impossible without the spacer. When you then mount the wheels and tighten the Wheel nuts, the bearings bind.
MKAH is offline
