Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 06-23-2009, 03:36 PM
  #9901
mr crum's Avatar
Originally Posted by trdsupra88
Are you talking about the top deck? as long as there is more than 1cm around the edge it should be strong and flex more...
yes topdeck and there will b more than a cm all around
mr crum is offline
Old 06-23-2009, 04:18 PM
  #9902
trdsupra88's Avatar
Trader Rating: 25 (100%+)
should be worth a try...along with the o rings
trdsupra88 is offline
Old 06-23-2009, 04:40 PM
  #9903
jag88's Avatar
Josh H. you have PM
jag88 is offline
Old 06-23-2009, 05:21 PM
  #9904
mr crum's Avatar
hey trd i cut it it flexs alot more wat do u think about taking the center screw of all 4 bulkheads out
mr crum is offline
Old 06-23-2009, 05:23 PM
  #9905
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
If you were to remove any of the bulkhead screws, you would want to remove the two closest to the center of the chassis.
IIGQ4U is offline
Old 06-23-2009, 05:27 PM
  #9906
mr crum's Avatar
would that give me more flex my problem is im runnin a ft on asphalt and that thick chassis has zero flex which is great 4 carpet but im not runnin carpet
mr crum is offline
Old 06-23-2009, 05:33 PM
  #9907
Airflow's Avatar
Hi, Ive snapped a second rear belt again.
Since AE belts are expensive, I want to use Yokomo belts and diff pulleys.
Can anyone give me the Yokomo part numbers for these items?
A racer uses this setup, I want to use it as well.
Airflow is offline
Old 06-23-2009, 05:53 PM
  #9908
revo61's Avatar
Trader Rating: 18 (95%+)
Replace the top deck with the itf top deck. Use 4 screws with orings and washers. You will have tons of flex. I would not recomend removing screws from bulkheads.
revo61 is offline
Old 06-23-2009, 05:56 PM
  #9909
mr crum's Avatar
thnx revo
mr crum is offline
Old 06-23-2009, 05:57 PM
  #9910
mr crum's Avatar
if ur breakin rear belt they are way too tight ive run tc5 for 2 yrs now and havent broke a belt yet
mr crum is offline
Old 06-23-2009, 07:01 PM
  #9911
trdsupra88's Avatar
If you can just order the two chassis...I ran the Ft upper cut like you explained until I ordered the top deck, I just recently ordered the main chassis and Ill let you know how it works compared to the FT on Saturday...I would leave all the screws on there and try the o rings
Old 06-23-2009, 08:31 PM
  #9912
Originally Posted by not home
battery tape is always the answer, i tried the strap a while back and when i knocked one corner the battery slid out. i believe the building instructions tell you to use threadlock or ca glue to lock the little screw in.
Oops, fixed my typo in the previous post. I got a friend to tape my battery in for the next heat, but as I mentioned I was thinking of alternating batteries every heat, which would require a lot of battery tape and patience to switch them back/forth.
For what it's worth, I had threadlock on the thumbscrew/grubscrew part which is what the instructions recommend.
BlueEagle is offline
Old 06-23-2009, 08:37 PM
  #9913
Trader Rating: 23 (100%+)
i dont have a problem with battery tape, i just undo the tape and pull out the battery still leaving the tape on the underside of the chassis and use the tape for about 6 or 7 more runs until it loses it's stick.
not home is offline
Old 06-23-2009, 08:47 PM
  #9914
trdsupra88's Avatar
Ditto
I reuse mine for a whole race day...4 reloads...I dont think Ill ever go back to the strap....
Old 06-23-2009, 11:10 PM
  #9915
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Battery straps also have a bad tendency to tweak your car too by putting too much pressure on it.
Jon Kerr is offline
