Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 12-31-2007, 01:21 PM
  #4981
Maybell's Avatar
Originally Posted by loopedout
any of you know where to get an aluminum screw kit for a tc5?
just my opinion...but aluminum screws are bad news on touring cars...
dont think you will find them on any factory drivers cars anymore...
Maybell is offline
Old 12-31-2007, 01:25 PM
  #4982
Trader Rating: 49 (95%+)
I'm not a factory driver so it should be ok.
loopedout is offline
Old 12-31-2007, 01:27 PM
  #4983
Jsaves's Avatar
Thanks alot Wallstreet, robk, Wease and Kraig for all the info.
Jsaves is offline
Old 12-31-2007, 01:29 PM
  #4984
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
I always thought aluminum screws into aluminum parts was not a good idea. Something about seizing together. Am I wrong?
Kraig is offline
Old 12-31-2007, 01:31 PM
  #4985
actually steel into into aluminum can cause corrosion, I been running aluminum screws in my rc cars for 18 years with no problems, didnt want a debate, just a link, thanks
Old 12-31-2007, 02:03 PM
  #4986
Maybell's Avatar
sorry, just trying to help....I hope you find some!
Maybell is offline
Old 12-31-2007, 02:08 PM
  #4987
Roadburn's Avatar
Are you running without the screw that attaches the motor mount to the left bulkhead? If you are than that is the problem. Many others have had this issue too without the screw. The chassis is flexing/twisting and with 64p it only takes a small amount.
Hey Corally, I checked all that, I'm a fanatic when it comes to my car. Thanks you for the info anyways
Roadburn, make sure you are running 3 screws in the spur gear. I was only running 2 in mine and had the same problem. I put the third one in and it went away.
Hey Kraig, that thought did pass my mind. To get the proper roll-out, you can't use 3 screws with some of these Spur gear manufactures. The gear just won't line-up for 3 screws. I'm generally always using a 109, 111 and a 113 spur. We generally have the roll-out figured out at my local track. An no matter what my foam dia. get to, it always falls into the range of those spurs. The 111 and the 109 I use the most. Does anyone know of a manufacture that has those gears and you can use 3 screws. Thanks all
Roadburn is offline
Old 12-31-2007, 02:58 PM
  #4988
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally Posted by PitNamedGordie
My ITF chassis will sag by .25 - .5mm in the middle. It is more of an issue when I use the battery brace. I now use tape and the problem goes away for the most part.
I have always used tape. Once I go back to the ITF chassis I will keep an eye on everything.
STLNLST is offline
Old 12-31-2007, 03:01 PM
  #4989
Phroz's Avatar
Just wondering how the TC5 is holding up against the Euro chassis like T2'008, Mi3, Corally etc.. I'm in the market for a new TC and wondering if the TC5 is the answer.
Thanks,
Ben.
Phroz is offline
Old 12-31-2007, 05:31 PM
  #4990
on the battery deal, are most of you taping your batteries in or using the brace? I ask because its a common thing im seeing so far the the guys using the battery brace are losing their packs in any decent crash
Old 12-31-2007, 05:52 PM
  #4991
Hi all ive just started on road racing and have just got a TC5 and running a 19t motor,how do you stop the rear wanting to come around out of a turn?
NZracer07 is offline
Old 12-31-2007, 05:54 PM
  #4992
I went to 2 deg rear toe to keep mine from coming around. you can lower the roll center if you have your diffs raised, that will keep it from turning so hard
Old 12-31-2007, 05:57 PM
  #4993
Ok ill give that a try,Thanks for the help
Old 12-31-2007, 06:52 PM
  #4994
Super Moderator
Kraig's Avatar
Roadburn, have you tried PRS gears? They seem to be a little more stiffer and might hold up to just using 2 screws.
Kraig is offline
Old 12-31-2007, 06:55 PM
  #4995
PitNamedGordie's Avatar
Well and with the PRS spur you can use 3 screws...heck you could use all 6 holes . They are great spur gears.
PitNamedGordie is offline
