Team Associated TC5
#5131
also, if a speedo comes with a capacitor, I would recomend using it..
#5132
hi, I've had a problem with wheels on the TC5 coming off about 4mins into a race. I've changed the stub axles - but there's still a wobble in wheel. I'm using nylock nuts. I'm starting to wonder if it's the CVDs. Has anyone else had an issue with this? Thanks for your help in advance.
Shev
Shev
If so check out this thread http://www.rctech.net/forum/showthread.php?t=175872 I believe John was having the same trouble and he found that the wheel hexes were slightly too small for the hex in the wheels so the wheels were rocking back & forward on accel/decel and causing the nuts to loosen, he fixed it by going to some Losi hexes I believe which are a tighter fit in the wheel
#5135
Did you not see the results from the novak race
brian jucha 3rd place overall 13.5 foam
bob stellflue BQ and won the b main with ease
keven hebert A main mod
The car with the hard suspension parts and the setup rob king posted the car was totally dialed!!!
just run bigger tires on lower bite surfaces.
#5136
I ran Jaco blues at the end of the summer...they are a larger diameter than CS/RP tires...because of the size I had to change down-travel and ride hight and thats about it.
#5137
#5138
The TC5 has had some good results here in South East Queensland - AUS.
Current QLD State Champion 07 in Stock
Just took 1st and 3rd in Stock at the Presidents Cup at the Bayside club. A small race that was very competitive.
Couple of questions............
Is the current 35wt Number 2 pistons still the choice for Asphalt Rubber tyres, or has there been some further developments.
What handling changes does changing the diff heights make to the car, for Asphalt Rubber tyre?
Cheers
Aaron
Cheers
Aaron
#5139
Sorry for all the questions,
If I were to change the Arm holders from say #1's to #3's in the same configuration, what handling changes would that cause?
Cheers
Aaron
Cheers
Aaron
#5140
#3 arm mount (high roll center) - more aggressive, less stable, tight layout recommended
#5142
#5143
#5144
Cheers
Aaron
Cheers
Aaron
#5145
Raising the diff will result in more onpower traction in the end you raised the diff. For example, putting the front diff to the highest position and rear diff to the lowest position will give you the most onpower steering and vice versa. I normally run mine mid low both ends, sometimes mid high in the front. If the driveshafts are straight your car will the more neutral on and off power. The driveshafts try to straighten out when accelerating which causes the handling effects.
