Yokomo BD9
#136
Oring sits flush. Put over snout as far as it goes.
As for alignment, there is a little notch and a recess - make sure these are lined up.
Also make sure the gears are seated correctly. If the main gear is not seated in the diff housing properly (on not over the pin) this will bind like you have described.
#137
Should I pre-soak the diff out-drive o-rings in diff oil in order to swell them up a bit before I assemble the diff? My kit is on the way
#138
For my experience, do not use the silicon oil to pre-soak the oring. Should use oring grease to seal up the oring to avoid the oring absorb the diff oil.
#139
BD9 Extra Parts first run
Ok so I have heard that the kits come with some extra parts can someone tell me what it comes with. I am thinking of ordering a kit from Amain but they dont have a lot of front end spares. I might need some arms etc
Thanks guys
Thanks guys
#140
The kit comes with extra front and rear arms, 2 4*C-hubs, 2 rear hubs and 2 steering knuckles.
#141
■ BD 9 kit early purchase campaign
In the "BD 9" kit ordered by November 20, we will implement an early purchase campaign that includes five spare parts (total amount ¥ 5300 minutes).
(Graphite spare parts bundled with the campaign)
· Steering block right
and left set · Front hub carrier left
and right set · rear hub carrier left
and right set · front lower suspension arms right
and left set · rear lower suspension arms right and left set
#142
Thanks looks like a good deal. Just bought one from Amain.
#143
Gear diff leaking issues
so I hear the o-ring for the diff doesn’t seal the diff that well and others have replaced it with a better one.
Can someone tell tell me what size o ring I need?
thanks
bill
thanks
bill
#144
I would recommend to just build the diffs per instructions using the seals that came with the car first before you go spending more on o-rings. I have already changed fluids on my diffs twice now with no leak issues.
#146
Thanks for the heads up I’ll give it a try and see how it works.
#147
Rear toe in
si I’m in the process of building my BD9 and was wondering what a suggested starting point for 17.5 Is. I am coming from an Associate TC7.2 and I run from 2.5 to 3 degrees for our local track.
Its an outdoor medium tracktion track.
The 3.8 the kit says to use seems like a lot but I do understand it’s not an Associated car as well
thanks for the help guys.
#148
Toe
#149
I just received my BD9 aluminum chassis kit on Friday night and I can confirm that the early adopter plastics were included - so nice to start out with spare parts right off the bat. Also the aluminum chassis is gorgeous!
#150
Spare & Option released
