Like Tree321Likes
Yokomo BD9
Old 12-08-2021, 10:00 AM
  #676
trx-1racer's Avatar
I recently picked up a BD9 off the forum here and I'm going through it and freshening it up. I see that the rear shocks have a shorter rod end then the front shocks. I don't see this in the owners manual anywhere... Is this the proper configuration, or should they all be the same?
trx-1racer is offline
Old 12-08-2021, 10:11 AM
  #677
acuratech's Avatar
Trader Rating: 28 (100%+)
Originally Posted by desaix
It is spool hub for BD8. You can't use it on BD9
I figured it out. The car I have is a mix of Bd7/8
it have the long shocks on it.
acuratech is offline
Old 12-22-2021, 01:11 PM
  #678
maximebeauvais's Avatar
Trader Rating: 7 (89%+)
Originally Posted by porsche928gs
With the mid motor configuration you will be able to drive the car more aggressively into the corners without loosing the rear end.
I did the switch. I kept all the same setting and I found it harder to drive. No rear traction. I guess that I need to change some setting? What will be a good grey carpet setup for a bd9 with mid motor configuration? thanks
maximebeauvais is offline
Old 11-01-2022, 09:19 AM
  #679
gene465's Avatar
Trader Rating: 52 (100%+)
Been awhile since anyone posted, Anyone running a 10.5T motor in the BD9, got an older BD9 and looking to set it up for super late model. Is it too much or will it need an aluminum chassis? If so what's a good FDR? Thanks
gene465 is offline
Old 11-03-2022, 12:19 PM
  #680
Last weekend, I ran the BD9 in stock class (17.5) and it was very good. Also run my other BD9 in USGT (21.5) and again great setup and car !
Old 06-06-2023, 03:55 AM
  #681
mac853's Avatar
Hi:
In case I didn't run long time on carpet meanwhile never with mid motor cars on this kind of surface.
Could anybody suggest what kind of screw position should put in beginning on rear stiffener of BD9 with arrowmax coversion kit, please?
Best regards
mac853 is offline
