Tamiya TRF103
#122
there's one listed several posts back in this thread
what set did you get?
specific for the 103?
Just put on the kit set up and get yer ass over to Cal on Sunday hahaha
#124
#125
Lots of TRF103 parts are arrived at TQ RC RACING.
FYI, Thanks.
https://www.tqrcracing.com/shop/prod...p?s_maker_id=2
FYI, Thanks.
#126
Cuda, do you happen to have any spare O Rings for the front suspension? For some dumb reason mine are failing?
#127
Find some small gauge steel wire (Lowes?) and twist tie them on instead of the o-rings. The o-rings are butyl rubber and fall apart and stretch out after a while.
#129
#133
This apply to the middle deck as well...it will start delaminate when installing the side sping screw if not applying enough CA, that hole is too close to the edge.
I like my TRF103, kit setup is fast and steady, not issue when completing with X1...the rest just driver's skill and luck
Also nothing need to upgrade...except 1 thing, the side links and probably the kit plastic pivot (part L5 i think). Strongly recommend to change them. They are too soft and got damaged easily.
I replaced them with #54460 and the car is perfect and hassle-free now.
#134
Hi guys,
so as there was a discussion on the carpet setups I uploaded mine (with alu Chassis made by C. Donath) and Alex Stockers (carbon Chassis) setup of ETS Rd.1 on petitrc.
Sadly I damaged my alu Chassis pretty badly at the warm up laps of A1 as i traction rolled, so I think thats why i lost my pace on finals day.
Feel free to ask me anything, but Chance of a fast answeris higher on Facebook as I am not that often on rctech.
Best regards
Simon Lauter
Best regards
Simon Lauter
#135
Simon it very enjoyable to watch you race on youtube in ETS. Congrats on doing so well with the TRF103, Have you tried the t-bar setup with the car? Any little mods you do to make the car better for you? Tks and good luck racing
211Likes
