Tamiya TRF103
#151
Note to self:
Apply Shumacher shake method
Disassemble completey, carefully place all components into shoe box and cover
Shake vigorously
Remove and reassemble completely discarding worn, broken or bent components
Inspect and be certain chassis has T plate installed and axle located in forward position.
Gently place freshly assembled weapon on carpet
Grab steering wheel, pull trigger and fire said weapon.
Document all results and proceed to podium
Shake vigorously
#156
You need to back off on how tight the screw is. Also, doing the X1 High Traction T-Bar double O ring seems to help.
#164
Bent rear bulkheads
Hey guys,
I look around on this thread and didn't notice anyone has been having problems with this but I have had 2 rear bulkheads bend on this car. Have never had it happen on any other F1 I have ever used so I am wondering if any of you have has the same problem. If so, do you have any alternatives or suggestions that you have used to fix it? Everyone I know that runs a trf103 in my area has had this happen and just bends it back. To add insult to injury, no one in the states seems to have them for sale and TamiyaUSA is even out of stock with no ETA. The car is by far the best car I have used on asphalt but this may be where I relegate it to TCS duty only. :-(
