Like Tree126Likes
Tamiya TRF103
Old 06-27-2018, 02:33 PM
  #61
TQ from the last weekends ETS set up.
jujubean is offline
Old 07-08-2018, 08:11 PM
  #62
vadersing's Avatar
Default O rings
I had a good run on asphalt yesterday. The car worked welled with lots of grip under 35 degrees Celsius, UNTIL the O rings at the ball connectors started to disintegrate. Any alternative O rings to use? Prefer not to glue.
vadersing is offline
Old 07-08-2018, 08:38 PM
  #63
mtveten's Avatar
Trader Rating: 28 (100%+)
glue is the way to go. I had one of mine pop off tightening the weel nuts when I built the car but havent had an issue since glueing the inserts in place.
Mark
mtveten is offline
Old 07-09-2018, 07:23 AM
  #64
Trader Rating: 80 (100%+)
o ring issues - are you guys making sure that the o rings are against the top surfaces of both the lower and upper arms? I was having the same issue (rings popping off tightening wheel nuts or leaning on arms) until I realized that I had the upper inserts upside down. the manual has a tiny "flip over" symbol at the upper o ring steps for the upper arm inserts.
Once I corrected the direction, I have not had one o ring come off. HTH
aracefan likes this.
Markus is offline
Old 07-09-2018, 07:31 AM
  #65
I have a few weekends with the car now and for me and another local TRF 103 driver, the link setup / transverse battery seems to be the easier and faster setup for low/medium parking lot. The car easily competes with the other brands of F1 chassis.
NutDriver and theflyingrc like this.
Markus is offline
Old 07-20-2018, 09:14 PM
  #66
Trader Rating: 29 (100%+)
Nevermind
rgirocz28 is offline
Old 07-27-2018, 07:20 AM
  #67
vadersing's Avatar
Default o rings popping out
I just wanted to share some good news to those with the o rings popping out issue. I changed the o rings for the ball connectors to 5mm diameter ones from another rc brand (for F1), and NO MORE POPPING OUT. I successfully tested one full track day under 36 degrees Celsius!
NutDriver likes this.
Old 07-27-2018, 03:36 PM
  #68
fat500's Avatar
Trader Rating: 32 (100%+)
please tell which ones
fat500 is offline
Old 07-28-2018, 08:07 AM
  #69
vadersing's Avatar
Team Saxo part number TS01161.
5mm inner diameter, 1mm thickness.
Old 07-29-2018, 09:41 AM
  #70
fat500's Avatar
ok thanks
fat500 is offline
Old 07-29-2018, 04:49 PM
  #71
fat500's Avatar
I am building mine with the kit o rings to see whats what
fat500 is offline
Old 07-30-2018, 08:04 AM
  #72
NutDriver's Avatar
Trader Rating: 20 (100%+)
Default X ray o-rings?
My kit is on the way. I have some X ray o-rings from the X1 that I'll check to see if they work.
NutDriver is offline
Old 07-30-2018, 02:06 PM
  #73
I just ran at the TCS race in Jackson, NJ. The F1 winner at this race had a dominating setup on his TRF103. I got to test drive it and it was the one of the few times I've driven any F1 car that could be driven like a touring car. Well behaved with no need to be careful with the throttle or steering wheel. Congrats to him. There were some bumps and bruises which effected the finishing order in the A main but the finish was: 1) TRF103 2) TRF103 3) TRF102 or 101
Markus is offline
Old 08-01-2018, 09:18 AM
  #74
CL
CL's Avatar
Trader Rating: 34 (100%+)
I built one with kit o-rings, and I have no issues.
CL is offline
Old 08-02-2018, 07:25 PM
  #75
vadersing's Avatar
Default Carpet setup
Has anyone tried running this kit on black carpet? Any set up advice? Thanks
