Like Tree126Likes
Tamiya TRF103
Old 04-08-2018, 06:35 PM
  #31
robk's Avatar
Trader Rating: 22 (100%+)
If the battery wont fit without grinding the ears off the cross brace, why do you need a second car instead of a second cross brace?
Also, why does it matter if the front end is heavier if it works better? Xray, Roche, associated, shepard, etc.etc all run a similar setup. The old front end is just not anywhere near as good as the newer cars.
robk is offline
Old 04-08-2018, 06:41 PM
  #32
f1larry's Avatar
Trader Rating: 17 (100%+)
If they didn’t intend for the transverse mounting of the battery I don’t think they would have designed the brace the way it is, it would have been wider all the way across from the inner tabs to the ends. I am guessing the intent is to leave it alone for inline setup or grind the inner tabs for transverse setup.
Originally Posted by mtveten View Post
Yes it can be easily modified to fit but out of the box the cross brace is is shaped for inline use only.
For many the apeal of a new tamiya f1 is a the ability to have a car that is tcs legal and competative with other manufactures. Modifying the car to make it competative with others results in tcs racers continuing to need 2 cars, 1 for tcs and 1 for everything else.
f1larry is offline
Old 05-02-2018, 06:40 PM
  #33
Hi Guys, I Got this kit early April and Completed the build 3 weeks ago. Have yet to try the car.
darenlsl is offline
Old 05-02-2018, 06:46 PM
  #34
I'd like to share some build photos but I have yet to chuck up enough post to add photo. Link of photos below. please cut and paste the txt to your browser. cheers.
link: flic.kr/s/aHskAup2Hf
darenlsl is offline
Old 05-03-2018, 04:56 AM
  #35
I like a lot tamiya car... But did you try on track? In this case, how did it perform? I am curious ...
Marco Donadelli is offline
Old 05-03-2018, 06:27 AM
  #36
nubs's Avatar
Are bearing wheels in the front normal for today's f1 cars or is that a tamiya thing?
nubs is offline
Old 05-03-2018, 09:25 AM
  #37
R/C Tech Elite Member
JayL's Avatar
all f1, in fact all f1 use the same wheels, thus bearing in the wheels
JayL is offline
Old 05-05-2018, 06:16 AM
  #38
I have yet to try it. Cos I have bought quite a number of car recently. (M07, TA07R, TB Evo7, BD8). So the TRF103 will have to wait its turn. keke.. Not enough time on my hands to try them all. I am also a Tamiya Fan and all versions of their TRF F1 series.
darenlsl is offline
Old 05-19-2018, 03:59 PM
  #39
NutDriver's Avatar
Trader Rating: 20 (100%+)
I have an F104GP running the 42286 TRF101 front suspension. Considering buying a TRF103. Raced against some TRF102s at the Ohio TCS race and saw a few broken rear pod components on them. Anyone owned the TRF102 and TRF103 who can compare/contrast them?
Scott
NutDriver is offline
Old 05-19-2018, 10:58 PM
  #40
MikeR's Avatar
Trader Rating: 15 (100%+)
Here you go;
NutDriver and Holmestead like this.
MikeR is offline
Old 06-08-2018, 09:36 AM
  #41
Trader Rating: 36 (100%+)
The cars are starting to become available in the states now I see. Has anyone had a chance to run one yet? Thoughts?
Jamie Hanson is offline
Old 06-08-2018, 10:12 AM
  #42
Trader Rating: 80 (100%+)
Car has been built. Electrics go in tonight. Hope it doesn't rain this weekend for the 1st run. otherwise... next weekend.
NutDriver likes this.
Markus is offline
Old 06-21-2018, 11:23 PM
  #43
Umh..... In step 6. The standard BB13 part. If you install as the kit setting, What is the caster on that? Has anyone experimented with mixing those settings?
jujubean is offline
Old 06-22-2018, 06:08 AM
  #44
I'll let you know this weekend but it is supposed to be 9degrees caster and 2degrees camber.
Old 06-22-2018, 12:28 PM
  #45
Yup.... I did not read the instructions properly. Trying to get that 0 degree camber....
jujubean is offline
