Like Tree211Likes
Tamiya TRF103
Old 06-22-2018 | 08:07 PM
  #46
mtveten's Avatar
Originally Posted by Jamie Hanson
The cars are starting to become available in the states now I see. Has anyone had a chance to run one yet? Thoughts?
I took mine out today for some laps, overall it was a postive start. I would suggest glueing the arm inserts in place the o-rings dont seem to do as well as on some other cars. Altough they say the t-bar is for low grip I found it to give less stability and forward traction than the running links on low/med grip asphalft. As expected the transverse battery position give better forward traction with increased entry steering. the inline position transitions quicker and hold tighter though through longer corners.
Overall I would say in link configuration it is a step forward from the 101. On 25.5 power it was as quick as my f1r3 but fell a bit short on 21.5. With more time I think It will be comparabe in most outdoor conditions but lacks the extreme adjustability to fit the same range.
mtveten is offline
Old 06-24-2018 | 06:09 AM
  #47
A TRF103 on pole at the ETS
theflyingrc likes this.
Gerd is offline
Old 06-25-2018 | 03:06 AM
  #48
yep and second of the race Unfortunately no photos or set up yet.
Gurneyflap is offline
Old 06-25-2018 | 07:09 AM
  #49
fat500's Avatar
A few posts up there is a pic of Suzuki's 103 has anybody noticed that the rear ball diff halfs seemed a lot thicker on his car what are those is that what is speced on the 103 or is that an option? I looked in the manual and it looks the same as what we currently run but his are noticeably fatter
fat500 is offline
Old 06-25-2018 | 09:28 AM
  #50
mtveten's Avatar
I think its just an optical illusion from the angle of the photo and thin spur making them appear thicker.
mtveten is offline
Old 06-25-2018 | 09:40 AM
  #51
mtveten's Avatar
After a sunny track day of med to med/high grip asphalt I was able to move past mt trusty f1r3 on a flowing circuit. The real surprise was t-bar setup that was completely useless in the low/med grip condition. Just like before the link config worked well driving like any other modern link car. The t-bar however was faster. With the grip high enough to help with forward traction the t-bar config carried more speed thorugh the corners lapping consistantly .2s faster. This comming weekend I'll up the power to the 21.5 power we run locally to see how it compares with teh added HP.
mtveten is offline
Old 06-26-2018 | 12:39 AM
  #52
kentech's Avatar
Pictures here:
https://www.facebook.com/media/set/?set=a.1935060486504723.1073742046.254298717914250 &type=3
kentech is offline
Old 06-26-2018 | 06:37 AM
  #53
Dan's Avatar
Dan
This car is legit!
If I still raced asphalt, I would be tempted to return to good 'ol blue....after racing orange for 3 years. hah
Dan is offline
Old 06-26-2018 | 04:33 PM
  #54
robk's Avatar
Originally Posted by kentech
Sounds like he ran a transverse battery if the comments translated from German are correct.
robk is offline
Old 06-26-2018 | 04:38 PM
  #55
robk's Avatar
Maybe I'm going to be proven wrong but I am excited about this car simply because of the T bar option on carpet. My F104WGP with a transverse battery is pretty close to my more modern cars. This might be a nice surprise.
NutDriver likes this.
robk is offline
Old 06-26-2018 | 05:35 PM
  #56
MikeR's Avatar
I think so because he has lead weights blocking down the middle.
And those Exotek stickers were worth .2 off his lap times!
robk, Rick Vessell and Qatmix like this.
MikeR is offline
Old 06-26-2018 | 09:36 PM
  #57
PDR's Avatar
PDR
Is that 0.1 second per sticker? Put me down for 15.
MikeR likes this.
PDR is offline
Old 06-26-2018 | 09:38 PM
  #58
Kevin CBR's Avatar
I get a kick when people in the US complain that 25.5 motors are "too slow" for F1. The ETS has a number of factory drivers in F1 and the spec esc and battery is the Scorpion 50a esc that has a set rpm limiter in it and very little tuning options and the Scorpion 25.5 motor that is a standard motor (not the hot 1s like we run here) and yet they have good turn outs and pro drivers running in the class. Simply amazing.....
Panda
Rick Vessell and NutDriver like this.
Kevin CBR is offline
Old 06-27-2018 | 01:48 AM
  #59
Mike, we need you to sort out the front suspension limitation for high grip tracks (less caster and camber)
Old 06-27-2018 | 02:31 PM
  #60
C van der Hagen's Avatar
Soon available from Sepes racing:
TRF103 upper arm mount plate, 3 and 6 degrees caster
C van der Hagen is offline
