Understanding F1 Tuning: Let’s break it down
#46
Would epoxy stick to rubber? Might have a better appearance.
#47
Epoxy would crack and break off as the tire carcass flexed. I wonder how the black rubberized CA would work/look?
https://www.amainhobbies.com/bob-smi...MaAu26EALw_wcB
#48
You can cut a slit in the CRC sidewall and stick a hook pic in there to grab the foam and reset it. Then just apply a little CA to the sidewall to glue up the slit you made.
It's easy if the foam is bunched up really badly from a hard crash and has a huge sidewall bump. If it's ok but wobbly, that's a bit harder.
#49
Capricorn RC ONE EP Foam Tyres Range | RCNews.net - RC Car News
I'm probably the only one who misses the foam tyre days
#50
whoever is gluing the crc tires does a horrible job. I have 4 sets and the front wobble all over the place brand new out of the box. Not sure if actually has any effect or not it just drives me crazy. Gravity and Hudy are glued near perfect with no visible wobble.
As far as sidewall glueing I have not seen any run on black carpet without glue on at least the front tires at my local track. I glue the fronts and rears and sometimes will still traction roll if I get overly agressive.
#52
gotta spend at least $60 for a set of tires for them to be straight trash
#54
Dreamer!!!! Foam brings a whole other level of frustrations lol. Adam you and I are lucky we race with a good group of drivers and we rarely have car to car issues (most issues are board meetings self inflicted) We could most likely get away with using foam and not worry to much about chunking them out but nothing is worse than a one run chunked out foam tire.
#55
#56
It's so easy to mount foams, they are cheap, I'll run the rubber tyres, but I miss the old days
#59
Rubber tires (and the carcass flex they bring) forgive a multitude of sins.
If you have tires that wobble to such a degree that your lap times are affected (i.e. they don't perform properly), then perhaps you should contact CRC for replacement.
