Tekno RC EB48.4 Thread
#1531
Did you move the spacers to the outside of the hub as discussed along with this setup? My issue with the car is a tad pushy through corners in comparison with an AE or XRAY. I've made some small adjustments with camber and toe and it's improved but I'm not 100% satisfied. I'm going to swap my car to the 18 rough setup and try it out. My only question is about the hub spacing if it's necessary or not.
#1532
How does one achieve full kick up
for 3x2.2 pistons are you taking the 3x2.1 and drilling them to 2.2?
#1533
Suspended
#1536
Suspended
There is too much slop in the rear hub assembly if you shim it like they suggest (5mm of spacers). The pic shows the space, but if you slid it over to the left it would be bigger. There is decent size gap left. Some of the setup sheets somewhat address this with an extra shim making it 6mm I believe, but I ended up printing an assortment of my own spacers in various thicknesses to get it just right instead. I am building two of these cars right now and they are both like this. I think the spacers needed were around 1.7-1.85mm (forgot the exact number).
#1537
1.7mm is a good thickness
#1538
Hi, upgrade chassis brace?
Hi I'm new to the tekno stuff but I'm going to buy a eb48.4 to use to mostly bash and take to the track, but in a lot of hard bashing videos I see the rear chassis brace breaks and bends the rear center driveline. I was searching and all I could find was the stock ones and I was wondering if there were any upgrade braces. Or if there was another fix for this. Tia
#1539
https://www.m2cracing.com/product.sc...categoryId=113
#1540
Thanks!^^^^^
Thanks and I probably won't be doing any thing crazy like that
#1541
Finished building the eb48, overall smooth build and i enjoyed it very much. Everything seems very well made and fit and finish is great. I painted the body bright orange (not really fluorescent). If only there was a way I could post pics as I haven't reached the post limit to attach files...
#1542
O ring on the servo saver
Hi
i am just in the process of building the eb48.4, I have lost the O ring for the servo saver, how important is it to have one?
#1545
Did anyone else have issues with installing the motor ? I did it in the end but it was a lot of hassle.
