Tekno RC EB48.4 Thread
#1501
There are some track layouts that I never break a single part... sometimes when learning a new layout that might have a large triple or quad and casing a large jump, I might snap an aluminum shock cap... I don't run the middle nor rear chassis braces, so I'll occasionally bend a center drive shaft. I think I bent a shock shaft once, never broke an arm, but the front arm holes tend to wallow out over time, and need to be replaced after about a year or so. After a nasty crash into a pole, I bent the front sway bar once... I usually go 2-3 months of racing before I might break a part after a weird situation. Maybe pick up a spare spur gear.... not a bad idea to check your mesh periodically, especially if you took a nasty cartwheel during a prior race, might be worth applying fresh thread lock on your motor mounts.
Best investment will be a pin replacement tool, I use this one:
https://www.amainhobbies.com/mugen-s...gb0541/p221425
I replace the pins in the driveshafts at the first hint of any flat spots... then you can expect your out drives to last indefinitely.
#1502
All depends on the track and size of jumps, etc...
Just one more question. Any wear issue on the spindle and spindle carrier?
#1503
No abnormal wear that I can see on my spindles/carriers... I tend to rebuild my car once every 2-3 race days and clean/inspect my bearings. Tekno does a good job with captured hardware and I think this helps reduce wear, only way I can see stuff wearing faster would be a seized bearing.
#1504
Got time to run my EB48.4 at the opening race at PRCP raceway. The track was changed to be significantly more technical. I went with what the previous owner had setup which I believe is this setup:
https://wwwcdn.teknorc.com/wp-conten...gh%20Track.jpg
For our conditions, it was significantly more loose than what i felt comfortable with.
So figure this as a starting base, what are some changes you would make for this setup for conditions that are more loose?
#1505
Ordered an eb48.4 yesterday from Tower. I'm going to take my electronics off my lx2e (2100kv motor and HW sc8). Super excited for it to arrive! It will be my first time building a kit as I figured why not make use of my time off this summer. I plan to have a fluorescent orange body and tires would most likely be duratrax lockups (I'm more of a basher than a racer).
#1506
Thanks, I'll give the two setups a compare. The track though is like really loose compared to what is considered commonly loose right now lol. Buckshots in M3 compound appear to be tire of choice.
#1507
Just wanted to give a little feedback on the current generation of setups. The smooth track setup is where you want to start for 90% of your tracks. If you can't handle the bumps, then you'll swap to the rough track.
For the smooth track setup, a few of us found it has a small push in the middle of the turn. This isn't a bad thing as it makes the car a little easier to drive without sacrificing speed. If you feel that you need a little more steering, you can move your front hubs forward and you'll have a ton.
The ackerman is missing from the sheets. It should be middle dot for both.
#1509
i am running the rough track setup except full kickup
I have slight push no power in turns low to medium traction
at night when moisture is in its perfect
thanks
Last edited by boudin4evr; 06-19-2018 at 08:41 AM. Reason: left something off sorry
#1512
311Likes
