Team Associated RC10B64 Thread
#2146
So I glued up my wheels from the kit finally as I used to drive a ZX6.6 and had a bunch of wheels. Well now I'm having serious binding issues on those front wheels. I saw someone else had issues but it seemed like they weren't using the right wheels. I went over the manual and my car to make sure it's assembled correctly and everything is as it should be. Looking at the AE wheels compared to my kyosho, it is clear to see the hex is deeper by a millimeter or so. Did I get a bunk set of wheels? I'm kind of pissed as I have a set of tires I can't use now.
I have tried shimming and loctite to be able to back off slightly but it leads to a loose fitting wheel.
#2147
#2148
#2149
I kind of wish I would of thought of this before attacking them with a dremel. I'll be ordering some though to make sure it doesn't happen again. Dremel seems to of worked though. Ran a pack through and it's fine.
#2150
Just be aware that the 4wd axles are thicker than the 2wd axles so 2wd hexes don't fit. I took a pair of the plastic 5mm hexes from a b4.2 and used a drill press to make the hole larger so they would fit the b64d axle. I think the b64 will come with 5mm on the front. So if you get 2wd hexes be prepared to drill the hole larger.
#2151
#2152
Since the new Tekno car is delayed for quite a bit and it's boring on club race days only have one car I was thinking about picking up the B64 as they have tons of parts at my track.
For high bite clay should I go for the B64 or the B64D? Seems like the B64 might be a better option? Going to run 13.5 on it.
#2154
Ray
#2155
Well I got my b64 today. Looking at the front arms all I see is a little more bracing around the shock mounting point. If I remember this is where the arms I broke snapped. Looking at the dif cases I can't see any difference, not saying they are not improved/changed, just that I can't tell any changes.
#2157
The diff cases are a different material, less fibrous / more black/shiny. There are also some fillets on the top deck mounting tabs.
I put some pics up on facebook here:
https://www.facebook.com/ray.munday/...95717219491703
Ray
#2160
I know it's all in my head but this car is so much easier to drive and tune than my previous wheeler. Consistently hitting a full lap faster with it. AE people are all sharing and chatting about who's doing what and trying to create the most competition and I think it makes every one at the track better.
Last edited by Costanza; 05-30-2017 at 08:01 AM. Reason: Could of been seen as trolling and I'm not here to start problems
