Team Associated B6 & B6D thread
#8926
Hey Guys, is the B6.1 Gull front Tower different than the B6 I know the holes are more to the inside compared to the B6 tower but is the mounting the same??, if different does the new top plate fit the B6? Thanks. Sorry if discussed before, searched and could not find it.
#8927
Looking for gear diff weight recommendations for carpet racing. What are you guys running?
#8929
Team Associated B6 - Dustin Evans - Reedy Race - OCRC - 18-21.01.2018
I have this set up in my car and it works quite well.
#8930
No problem glad you like it. Did you run it with the under battery weight? What motor?
I just tried this set up on my sons B6 and love it. Crazy thing is it quite a bit different than the Evans setup.
http://site.petitrc.com/setup/associ..._OCRC20180328/
#8931
No under battery weight,im running a 6.5t.car drove nice,and im kinda new to 2wd but looked like a average driver.might try using -1 toe out in the front next time to wrap around the 180 a lil better,but it could be my driving.
#8932
Can anyone post pics of their setup in the steering servo area? Looking to setup my buggy and having issues figuring it out.
Thanks!
Thanks!
#8933
Deleted. Sorry I thought this was the b64 thread.
#8934
#8936
When running the gear diff with 2 gears, should the other shaft be removed, or should I keep it there?
#8938
#8940
Hello,
Can I use ASC91760 alloy rear hubs without the ASC91550 hub bearing inserts on my B6D?
