Team Associated B6 & B6D thread
#6799
That's no biggie, doesn't mean you need to fuss with boost settings as well. You can either gear it as low as possible and add zero timing (boost) or go more conservative and add some ESC timing if you feel you lack straight away speed. I generally avoid adding ESC boost even in open classes. I just stick with pinion changes
#6800
Also it's been like 10 plus years. Remind me how to find final drive ratio.
#6801
Team Associated B6 & B6D - Charts - Gear Ratio & Arm Mount Inserts
#6802
I just coped a b6 and the build is almost done! excited to run 2w buggy on clay again. its been almost 2 years. some good material in this thread and a great wiki too!
#6807
I have a question, I'm having a slight issue with my car hooking coming out of the corner, the front end grabs and the rear end swings around. My track a Med grip and I'm running the lay-down tranny with a exotek battery brace.
setup
front oil 30, white spring 1 limiter
1.5 mm under ball stud
middle on tower, outside on arm
rear
shocks are on the rear of buggy
27.5 oil, green spring 0 limiters
shocks middle tower, in on the arm
3.5/1 toe with it .5 in and center
1mm under ball stud
hub are in the stock settings
25 gram C
Im running out of idea . I am the fast buggy there and win all the time just looking to get the car better. im not sure if more anti squat will help this or make it worse.
setup
rear
1mm under ball stud
25 gram C
#6808
