Team Associated B6 & B6D thread
#6496
#6497
Decided to get back into the hobby so bought a B6D just before Christmas. After the longest build ever I think it's ready to go start practicing
#6498
Anyone try any of the pre-cut TLR wings (particularly the one with the cut-outs for rear-mounted shocks)?
We have a jump at my track that is just barely do-able (for me) in 17.5, and I'm eating wings for breakfast. Don't get me wrong, I've gotten really good - and I mean REALLY GOOD - at cutting them out, with all the practice I've had... but if the pre-cuts are compatible, I wouldn't mind stocking up.
Thanks!
Thanks!
#6499
Do you mean no need for the added weight of the brass c&d blocks? Or do you mean no need for the brass bulkhead? I already have the alum bulk and c&d. But thought the brass bulk would be a good upgrade. How do you like the brass bulk with the alum c&d setup? Not nose heavy?
#6500
So, built the B6D up, and finally got some electronics in it. Using this mostly as a practice car, but I might do a few races just because....Been mostly a carpet off road racer the past couple of years and looking forward to getting a car dirty. Here's a couple pics of the wiring. I measured the esc wires when I had the stand up transmission installed and decided to leave them long with the lay down installed just in case I ever need to go back.
#6502
Schelle's gearbox shims come with directions, and those directions just say to install the shims and add 2mm of droop. I also got the Schelle motor plate to drop the motor.
I thought the point of this mod was to change the roll center, but shimming the gearbox alone won't do that, you'd also have to shim the C/D blocks and the rear camber mount. Seems the only benefit to this change is that it corrects the angle of the bones for those of us with a lower ride height?
#6503
Can you elaborate?
#6504
they used 2mm aluminum washers on these set ups, long rear shock eyelets
Team Associated B6 - Spencer Rivkin - Buggy Asia Madness - Shanghai - 31.03-02.04.2017
i'm rather amazed how soft they went on springs for a smooth hi-trac astro
#6505
#6506
I know they are different but I've never looked at that site and I just didn't know if they make em for gullwing. But I totally forgot I was running JC rear tower and revolution design front. I wonder if those protectors would fit those towers. I didn't glue my towers only cause I hate the way they come out looking when I do that. Does anyone know what I can use or how to apply superglue or tire glue so it doesn't dry white and shitty. I've seen some guys that come out shiny or glossy and they look good but I've never been able to get it to look like that.
#6508
Well I had a new one tonight. Putting the final touches on the new B6D so I thought I's set the slipper & diff. Tightened the diff screw and heard/felt a pop. Diff will not tighten at all now. Opened up and found the diff adjustment screw had broken. My money would have been on the plastic nut stripping but the screw broke clean at the threads for the nut. Luckily I had the ball diff from my T5M. Part numbers for the screw are the same so I was able to make it work. Anyone else had that happen? I wasn't putting that much pressure on it.
#6509
#6510
