Team Associated B6 & B6D thread >
Like Tree649Likes
    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Old 08-25-2016, 04:04 PM
  #2836
The horn is about .5mm - .7mm too small by the looks of it. I can't even line it up for the screw.
microjam is offline
Old 08-25-2016, 04:12 PM
  #2837
3n90t's Avatar
Originally Posted by mellow
I think the spline is just extremely tight fitting. It should go on there...now getting it off is another story.
Yeah, from My B5, B5M and B44.3, they are tight but they are right.
I find that it's better to install the blue collar on the horn, then gently press horn on the servo with a hobby vise or similar. To remove, I just use a flat screw driver to slowly yank out
3n90t is offline
Old 08-25-2016, 04:40 PM
  #2838
Suspended
Originally Posted by rvrslt1
I am having an issue with my car pushing real bad in the corners. What can be done to reduce this?
Adding front droop helped my push on my B6D.
Popcornfart is offline
Old 08-25-2016, 06:45 PM
  #2839
Hey I just wanted to follow up on the servo horn for "Futaba" thing. I finally hammered it down with a small mallet that has one plastic hammerhead, made for wristwatch band link adjustments (can't post photos yet, cuz too new here). I basically had to slightly ream a new spline grove in to the servo horn. I was able to remove it with needle nose pliers, just prying it off. All good now!
microjam is offline
Old 08-25-2016, 07:06 PM
  #2840
mellow's Avatar
Trader Rating: 24 (100%+)
Good to hear!
mellow is offline
Old 08-25-2016, 07:12 PM
  #2841
goehm's Avatar
Trader Rating: 45 (100%+)
Originally Posted by timannnn6
Their site was hacked and the last backup they had was from November 2015. All new data gone.
Actually, lots is still there. If you go to the main page with setup links to all the brands/models you won't even see B6D.
However, you can go directly here and see B6 setups (as recent as 08/21/16):
http://site.petitrc.com/setup/associ...tedRC10B6.html
goehm is offline
Old 08-25-2016, 07:18 PM
  #2842
mick33b4's Avatar
Trader Rating: 14 (100%+)
Thanks for the help. Will try to turn a little more
3 gear lay down. Brass C mount AE front bulk head Gray front 32.5 oil 2x1.6 green rear 30wt oil green spring 2x1.7. Schelle rear hubs 22mm front and back ride. -1 camber front and rear. Clay track with proline electrons
Real close to Kurt's set up from Schelle
Try lightening up the front spring. Go all the way down to green, and see how it feels. The pace the pros can push, plus the amount of brake they use in every corner makes their setup different than us mortals. Stiff front spring makes the car turn in harder, and easier/smoother to throttle steer out.
Adding weight can get you in to trouble too. Try going back to stock plastic. Between the 3 gear lay down, and extra front bulkhead weight, probably too much front weight bias for the grip the fronts can generate.
mick33b4 is offline
Old 08-26-2016, 01:01 AM
  #2843
ray_munday's Avatar
Default B6D Outdoor setups
Hi guys,
We have been working hard on low~med grip outdoor setups with the B6D in Australia and I've posted up some info on our latest setup sheet and what we have found. Any questions please ask.
http://www.rctech.net/forum/14637375-post1257.html
https://www.facebook.com/ray.munday/...55775313306959
Ray
ray_munday is offline
Old 08-26-2016, 06:21 AM
  #2844
Suspended
Originally Posted by psycho02
Any tips for associated x rings? Soak em? Slime em? Just put them in?
Kody says 30 minute soak. No slime.
Old 08-26-2016, 07:41 AM
  #2845
Orion_2kTC's Avatar
Edit: Running stock
I can't search via mobile, so sorry.
What's everyone running for a battery? I picked up a Reedy 5300 70C. It was recommended by a local pro driver on the basis that it will be more consistent throughout the run on the track. It is however 60 grams heavier than the 3900 mah counterpart.
Orion_2kTC is offline
Old 08-26-2016, 07:45 AM
  #2846
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
Im running the protek 4250mah pack. It's a full size shorty. There is, imo, no need for the slim shorty packs in this car.
Matt Trimmings is offline
Old 08-26-2016, 10:01 AM
  #2847
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Socket, you made it back to rctech. nice
Wildcat1971 is offline
Old 08-26-2016, 10:02 AM
  #2848
mellow's Avatar
Anddd..gone
mellow is offline
Old 08-26-2016, 11:09 AM
  #2849
Anddd..gone
Poor socket
Old 08-26-2016, 12:14 PM
  #2850
Planning to get a b6d. This is my first 10th scale 2wd buggy.
What are some basic must have upgrades to start? I'm planning to run stock class at ocrc. Anyone know how much weight savings the titanium screw set and the turnbuckles give?
M2126 is offline
