Team Associated B6 & B6D thread >
Like Tree649Likes
    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Old 08-10-2016, 12:30 PM
  #2476
Suspended
Trader Rating: 61 (100%+)
Originally Posted by racer1812
I like the Motiv motor. Paul L is a pretty cool guy, and semi local (3 hours away)
I definitely got that vibe in my emails with him. Super nice about the whole transaction.
The motor is not slow.
Socket is offline
Old 08-10-2016, 01:17 PM
  #2477
tony montana's Avatar
Trader Rating: 76 (100%+)
I'm just curious about laydown still. I do think it's gonna take over just like mid motor did over rear motor. I have the 6d with the laydown but only have a couple of packs threw it so far. It definitely is a little different. Is there a setup out that is for a medium bite indoor track that runs slicks.
tony montana is offline
Old 08-10-2016, 01:26 PM
  #2478
Suspended
For outdoors, no. For anything medium bite or more? Yes.
Socket is offline
Old 08-10-2016, 01:33 PM
  #2479
Sorry yes for indoor. I have been looking around and it seems like setups are all over the place. When I ran my b5m ce I put cavs roar Nats setup on it from last year and it fit me perfect. Was almost sad to sell it and get a 6d lol.
Old 08-10-2016, 01:34 PM
  #2480
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
Take a look at Kurt's setups he has been posting to FB. They should also be on the Petitrc site. FB is either Kurt Wenger or Kurt "Coach" Wenger.
Matt Trimmings is offline
Old 08-10-2016, 02:37 PM
  #2481
SMcD's Avatar
See you soon buddy Looks like you will be one of the first guinea pigs
Guys are running the D, but I haven't seen lay-down yet. Heading up there to watch tonight. Will let you know if I see anything interesting.
SMcD is offline
Old 08-10-2016, 03:20 PM
  #2482
What's up Sean, I actually already did try laydown at mimis a couple of weeks ago. It wasn't terrible but I know it can be a lot better.
Old 08-10-2016, 04:19 PM
  #2483
SMcD's Avatar
Ya that's what the guys told me. No one is running it tonight. You're the first.
SMcD is offline
Old 08-10-2016, 04:22 PM
  #2484
I'm going up again in the next couple of days. Gonna make some changes and try it out again.
Old 08-10-2016, 07:58 PM
  #2485
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
http://www.redrc.net/2016/08/ruddog-...for-rp120-esc/
http://www.redrc.net/2016/08/jconcep...o-front-wings/
RCBuddha is offline
Old 08-10-2016, 08:48 PM
  #2486
goehm's Avatar
Trader Rating: 45 (100%+)
Hey KC - Tonight was my first time out with the B6D/standup, and ran it at Mimis. I practiced for 3 minutes to see if I wanted to run that or my SRX2. I opted for the B6D. We went right into the quals and mains (and I only did very minor tweaks after each qual). By main time I was feeling more comfortable and actually got the track record. It's the fastest I had ever run there, with my fastest hot lap. This was also on Primes that are a few weeks old. Unfortunately, I got 2nd in the main - Chris beat me and needless to say his name got to be on the board. Total bummer!
My only point is that kit form you don't have to do too much to get it to work at Mimis (at least with the standup). I have a total of 27 minutes on the car. I have a laydown on order, but I think I'm going to try to work on refining the standup setup for a few weeks, and then spend a few weeks on the laydown. Let me know what you end up with setupwise with the laydown (and I'll give you my standup setup when done!).
goehm is offline
Old 08-10-2016, 08:55 PM
  #2487
suby723's Avatar
Trader Rating: 21 (100%+)
Steel weights are available at tower hobbies right now.
suby723 is offline
Old 08-11-2016, 06:09 AM
  #2488
I continue to be impressed with the durability of this car (knocks on wood as he types this). Probably have 15 packs through the car now with TONS of cart wheels and pipe slappers and short of the rear wing looking a little more haggard, the car has had zero other issues.
Schuie Driver is offline
Old 08-11-2016, 11:52 AM
  #2489
Lots of B6 and B6D in stock at Tower and AMain. 1 for everyone! Comon e-cash promo this weekend we need this on again!
I love playing with the AMain shopping cart. Let's you really see the stock levels. Right now 51 of the B6 and 83 of the B6D in stock.
LOL
190mph is offline
Old 08-11-2016, 12:12 PM
  #2490
team green's Avatar
Trader Rating: 14 (100%+)
Mine are in my buggy already. I went with 36g under the servo and 13g aluminum under the esc. Also use brass weights under the battery. total weight of my buggy is 1556g.
team green is offline
