TLR 22 3.0 Race Kit Thread!
#4683
#4684
I run the aluminum gear diff with the SR slipper eliminator on my 4.0 on carpet with no issues
#4685
#4686
Anyone running dirt and install the 4.0 rear camber block on their 3.0? Did the new inner hole make enough difference to warrant the $20 price tag?
#4688
#4691
Most likely the +3 hubs, if you run the std hubs with the raised diff I believe the driveshafts come out. If you upgrade the to 4.0 hubs once you have the metal tops you can get the composite parts very cheaply.
#4692
What you guys think of the 3.0 in 17.5 compared to the sr 4.0? I have all of the sr stuff for my 3.0 and it’s laydown with the xfactory conversion putting the shocks on the front of the rear arm. But one issue I’m having is I installed the the sr diff and idler gear and top shaft but the tranny seems really tight?
#4693
Picking up a new in box 22 3.0 buggy(not SR)
What if anything besides what comes in the kit should I consider buying?
#4694
Looking at setup sheets from different drivers, I see they use Yokomo springs, but there is 3 different types. Which one are they using. Ys, Yas, or ultra performance?
#4695
In order to use a 70 tooth or lower spur gear on the car, i would have to go back to 22 1.0 style slipper pads. Will they work with the slipper plates that come with the car?
