TLR 22 3.0 Race Kit Thread!
#4667
What type of surface do you race on? Do you have any problems with great wheel spin when you apply the throttle? What motor size are running?
#4669
#4670
Tlr 22 3.0 as a carpet/astroturf buggy
I just bought my kit but now a new indoor carpet track has opened near me and just found out that hobbytown in Tucson az has laid down astroturf as their racing surface. My question is the 22 3.0 a capable carpet/astroturf buggy without heavily modifying it? I was planning on installing new gear diff but that's about it besides tuning it. Any help would be helpful. Thanks
#4671
Yeah you can race it just fine. Although it's not the latest and greatest. But then again are you a fast and consistent driver? If not you really will not notice much of a difference.
#4672
I currently have the Exotek laydown in her. I had the original 3.0 SR gearbox in her. Same install.
I purchsed 4.0 stiffzel arms, I purchased an extra front sway bar kit, which included the "plastic" front camber assembly,
I flipped the shocks around to the front of the new rear arms, you have to install spacers. I used the original shock mounts, loctite the nut on.
I screwed two ball studs into the back of the rear arms.
Take a Dremel and cut the two ends off the new front camber plate, YOU WANT THE ENDS AND YOU WANT IT WITH THE PRE CUT SLOTS ALREADY IN THE TIPS, so cut more trim later. But you need the sway bar grooves.
Unscrew the 2 rear camber plate screws, get longer ones, slide the two ends onto the camber plate, install sway bars on rear of arms. Use links included in kit.
#4673
FIRST get a gear diff, you will destroy the ball diff in a short period of time. Losi makes a pre built one for under $30 which works just fine.
Brass weights under servo, under batter, under electronics. IF YOU HAVE A 3.0 SR then The tlr weight plate doesn't fit directly under the electronics, u need to grind it to fit into the electronics slot.
If you install these weights you really don't need the brass front bulkhead.
Springs We run AE PURPLE front, AE BLUE rear. You can get Losi black and pink, but for our track the Ae work better.
Shock Pistons 1.6, 1.7
Shock oil we started at AE 40 frt, AE 32.5 rear
Front sway bar kit.
FRONT AN REAR HRC MOUNTS.
A laydown would be great at some point, Exotek makes a kit including battery hold down, that your 3gear internals just drop straight in.
I found as I had to replace "worn pieces" (crash damage$) I swapped front parts out for 4.0 suspension pieces. Bolt right on.
In the past 4 months I have swapped the entire front over to 4.0 and the rear arms.
Have front and rear sway bars. Put a Exotek laydown in.
For me she's just fine. Pm if you want photos.
#4674
I run mine on turf surfaces now just fine, with some mods you can make as you go along.
Front sway bar kit.
Front sway bar kit.
#4675
Happy Thanksgiving
Happy Thanksgiving to all my fellow TLR racers. Be safe
#4677
#4679
Can someone please direct me to a off-road carpet setup sheet,
