TLR 22 3.0 Race Kit Thread!
#3916
As someone who owns both cars, built them both from kit form up to carpet cars we drive on dirt, the tlr is a superior product. Not saying the AE is bad by any means, but have you ever wondered why there are all these aftermarket companies that make everything under the sun for AE cars. The quality of components isn't as good as tlr but they get the job done.
As far as driving, one would think they should be somewhat similar... they're not.
AE car is very aggressive and can be pushed very hard, as long as you can keep up with it. The tlr car, very smooth and flowing, car rolls well in transition, jumps very well and is a pleasure to drive.
Both are awesome cars and the misconception that one is drastically cheaper than the other, not true. Very similar once you get your AE "tuned up"
#3918
i run the 17.5 rpm, with a yellow torque rotor. i will be trying a 17.5 regular with a torque rotor very soon, i have been told they are punchier...
that said the rpm with tq. rotor is very smooth and fast...
#3919
Frank,
Can you comment on standup vs. laydown for the average club driver on indoor clay? For carpet, the original laydown is a requisite to go fast, in my experience. But let's say as a club racer guy, when I hit the clay, am I going to have a much wider setup window with the standup layout? It seems that for stock racing, the laydown is a greater payoff than it is for mod, as carrying corner speed is critical to turning good laps. But would you think that going with the spec racer kit out of the box is going to be better for med-high to high-bite clay, or is converting an original kit to the upcoming dirt laydown better? I'm trying to get a handle on the direction I want to go with my rigs. Especially since I have to travel to hit clay, I don't have the chance to dial in my setup week after week on the same track. Do you think I'll have a higher chance of getting a decent setup with the standup, and consequently turn faster, more consistent laps? Is the ideal laydown setup for each track a much more narrow window that I am likely not to hit in one afternoon club race, therefore making the standup better for me? Or is the window about the same either way?
I hope you can see where I'm coming from and provide your insight, as I know you probably answer these types of questions around the country. Thanks as always for your great support and dedication to us, the user base of your products!
#3920
Frank Question
At the RC excitement race you guys still ran laydown. Question is why not stand up for this track as it seems like this track seemed to be on the lower end of the bite spectrum. I pose the question because I run on a track that was copied from that one and bite is normally very low to at times medium.
#3921
Frank,
http://www.rctech.net/forum/14647251-post3404.html
#3922
Frank did a good job of addressing this earlier in the thread:
The only place I think a laydown is a big difference for a guy like me is on carpet... I speak from experience! It really transformed me from a bottom of the A-main or even getting the bump from B guy into a podium contender at my local carpet track.
#3925
rear wheels will fit but the offset is different from the 2.0. You will have to make up the difference with a spacer on the outside of the wheel so they can be properly tightened.
#3926
#3927
I did bring both cars to RCE, but my laydown car was good from the start. For me, the laydown jumps a little better, and just about always has more corner speed. The RCE track is a "roll around with tight lines" type of track, versus a "slide the car and man handle quick laps" type of track. When you get speed from how quickly you roll around the track, then laydown it better IMO. But, I'm also a pretty experienced driver. I do know that the top 7 or 8 in mod were all running laydown.
For the type of tracks where corner speed is king, how much of a difference do you feel the laydown makes? In other words, if I'm 1 second per lap off the pace, will the laydown put me there? Or is it more on the range of 0.1 or 0.2 seconds? I know for carpet it made a huge difference for me, maybe a whole second per lap, but I think that's also because it allows proper suspension geometry at low ride heights. Most others are slamming the car to fight traction roll, but don't have the correct geometry so their handling and jumping is compromised.
#3928
So I normally run on carpet, but I do get indoor clay about 4 times a year. (I'm looking to up it to once a month on clay though, I just have to commit to traveling more!) For someone like me, would you recommend sticking with the standup or going ahead and committing to the laydown? Does that recommendation differ between mod and stock? I have the laydown on my carpet rig, but I'm trying to figure out how I'm going to set up a dedicated clay rig.
#3929
#3930
I think this is a great place for all of us owners and prospectors to come together and share our ideas. Sometimes constructive criticism is part of that discussion and in my experience, as long as it's conducted in a respectful manner it's usually not a problem.
That being said, it's obviously up to the moderators how this site is used. I'll make sure to keep your suggestion in mind in the future.
