TLR 22 3.0 Race Kit Thread!
#2896
Any tips for getting this car to steer in low speed turns? I run at an old school real dirt, bumpy blown out track (nickname is the sand box) and it is just plowing in the lower speed turns. Currently running kit setup with multibytes on the back and ribs up front. Tried mini spikes up front in the second heat and it still understeered badly and was squirrely in the other areas where it was good before. For the main I moved the battery halfway up and it traded the low speed push for a high speed one. Overall I like the car, it's easy to drive and jumps well but need to get the steering right. The track basically races once a month and its an hour and a half away so I don't any time to practice.
#2897
http://site.petitrc.com/setup/losi/S...ntyTwo3.0.html
http://www.tlracing.com/Products/Def...006#prodSetups
#2898
try going up on rear spring to the pink. Also maybe loosen the diff a tiny tiny bit.
#2899
lol, it's funny sometimes how many people know the sandbox, i.e. gobles. thanks for the tips so far.
#2900
#2901
We had the local club carpet champs here on the weekend and man was it tight at the top. The main brand being run around here is the yokomo with an odd S-works and Losi. I'm loving my 3.0 and am always fighting at the top. I haven't got the laydown kit yet and still not sure if I'll get it. I'm basically running Frank's pre laydown setup but lowered an extra 2mm. The only place I struggle is with an on power push and high speed corner entry which seems quite common, this also means i chew my front tyres quit badly. Has anyone found a good fix for this? As with the guy above, we get very little practice time so I struggle getting time to test different ideas.
#2903
I run kit pistons as well...
It felt really good at jcon. Ofc i am not the fastest driver around so im sure there are more changes that should be made but for now i dont want to mess with it
#2904
with the laydown kit are guys using a short servo or full sized??
#2905
I know Frank and Jackie are using the Spektrum 6240 short servo. They are also mounting it behind the mounts (using the TLR/EXOTEK aluminum mounts) to get a little weight off the front end. You need the aluminum mounts to be able to do this.
edit: You can see this in Kevin's pic below.
#2907
Which rear hexes are you running - +.75mm or +1.5mm? What is the benefit of one vs. the other?
Do you have to use different rear axles?
Also, after reading (some of) Fred Swain's posts in the camber gain thread, I think I'd like to try a higher roll center. Does anyone use the HRC front pivot block and/or rear HRC pivot block sets? Are they even necessary?
BTW, I will soon install the exotek laydown and I have the +3mm rear hubs to try out as well - if that makes any difference.
#2908
I run the HRC front pivot. Makes it easier to drive.
#2909
There is not a "MAP" price on the laydown kit, only for full vehicles.
I use the SPMSS6240 which has full size specs in a 3/4 size servo.
He is correct
There is a small cut needed to the mud guard, and some material needs to be removed for the servo horn and link.
In the rear, the +3mm hubs change the roll center. In the front, we all run some variation of an HRC front pivot.
If you run +.75mm hexes, you are probably too wide to be legal. If you are running 1.5mm hexes you are definitely too wide to be legal.
