Hot Bodies D216 1/10 2WD Buggy!
#1156
I know I’ll get it dialed in and it will be a great car I just wish there was more support from HB. For those that have replaced the idler gear with the aluminum version have you had issues with the diff gear? Is the aluminum top gear a noticeable improvement in acceleration? Thanks.
#1157
Tech Legend
Trader Rating: 51 (100%+)
#1158
There’s places to get parts for it A-main, Absolute Hobbyz , Beach rc , EBay sure others . I’m glad this buggy came with a gear diff not a fan of ball diffs been there i run on high bite clay and med traction mixed clay/dirt .
The guys i race with run the gear diff with 1000k or a little higher and they looked fine on the track .
#1160
Im running blue springs up front and yellow rears, stock shock oil. I run 21mm ride height f/r for medium bite clay. I also run the 1.4 sway bar.
#1162
Yeah sway bar for now. We run indoor clay here in MN during the winter months. I'll probably run without the sway bar once spring comes for outdoor dirt tracks.
#1164
I just need to get the radio installed and finalize set up and hit the track tomorrow. I'm excited like you!
#1166
After reading a ton of posts on the D216 Facebook page I’ve taken the rear of my car apart to do a few mods to hopefully eliminate the gear problems. One person on FB recommended putting a 3x35mm screw in the right front suspension mount to replace the std. 3x20 screw. This will make the area in front of the diff bearings more solid. After looking at the trans case very closely I am going to attempt to make two side braces placed just under the out drives to bind the front of the transmission case to the rear portion that holds the diff in place. I’ll be using 2mm thick carbon fiber. Lastly I’ll put slightly longer 3x10 screws in the rear right and left of the diff cover. HB’s designers made an error with the transmission case design which leads to the diff moving away from the idler gear under high torque loads.
#1168
Hum with the alum idler gear wouldn’t that eliminate the strip issue ? That’s a good idea though with the carbon plates if i can’t do them il try the longer screws like you said .
I’m thinking of getting the chassis brace stiffer also to help with it along the alum idler gear .
#1169
#1170
One guy on the FB page suggests using a gear from a Serpent car. He says it’s a direct drop in that offers more durability.
https://www.amainhobbies.com/serpent...500525/p544117
