Serpent Spyder SRX-2 Mid Motor Buggy Thread
#1982
Links:
Here's a FAQ that I posted on FB:
http://www.petitrc.com/setup/serpent...srx2/SRX2_FAQ/
A lot of the quotes by Billy were actually made on the FB page. That's the kind of info that we get there and not here.
#1985
I would suggest a HW Stock Spec ESC. You can get the full blown v3.1, but really for the 8.5T motor the stock spec will run that just fine. The biggest differences are the aluminum bottom case, and the heat sink on the stock spec is not quite as nice as the XERUN v3.1. However, I run the Stock Spec in my MM with the HW 8.5, with no fan, and it runs great all day.
http://www.hobbywing.com/product_show.asp?id=289
#1987
How much runtime should I get running a 8.5t + 18 pinion with a 4400mAh shorty pack?
I ran my MM last Sunday in a mid-sized track and got about 5 minutes.
It ran great with the RCShox pistons. I need to do some slight adjustments (It pushes a little bit) and the steering rack screws got loose, but I was indeed impressed on how it drives. Other than these and minor issues I need to fix, I really like this buggy.
#1990
I made runs over 25 min yesterday on a high bite med size carpet track with a 7.5T on 78/20 with a 4600 shorty. and full power till the end.
#1991
Dang 15- 25 mins!
Anyone using a Tekin RSX that can share your settings?
My cutoff is set as 2S (I guess I will change it to 3.5v)
#1992
The HW ESCs are pretty sensitive so for those we turn it off, or turn it down.
#1993
You reference using the 3.1 - that is actually a 120A ESC.
only thing is you cant tweak the settings like a 3.1 but you're right about the 120 amp thing.
#1994
Both have the same programmable items actually.
The ESC in your signature doesn't have all the settings.
