TLR 22-4 THREAD
#4141
I must say Horizon's customer service rocks, first time I have ever had an issue and felt the need to contact them. Sent them an e-mail with a picture of the broken rear axle, and they are sending me a not only a driveshaft set, but also a wheel nut set, pin set, and rear hub set as soon as the axles are back in stock. Just another reason I am glad to run TLR stuff.
#4142
So I was testing out caster blocks and front sway bar yesterday while I was at IERC. I'm wondering if anyone else has played with the front sway bar.
I felt that the 10* casters made the steering more consistent and made it easier to hit the same line entering and exiting the turns.
I ran the thin (white) swaybar up front and noticed that it kept the rear of the car from snapping around too fast. I was running consistent mid to low 23sec lap times with the sway bar up front and mid 24sec lap times without the swaybar up front.
Has anyone else tried the swaybar up front? Just wanted to see what everyone else thought of using it. Thanks!
#4143
I have not trued the front sway bar yet but maybe I will now. What is the traction like where you ran it ?
#4144
Interesting observation about the buggy. Below half throttle you can hear the motor spinning and the drivetrain I guess. From about half to full throttle down the straight the buggy actually runs near silent. Just a high pitched "whiiiiiiiiiiiiii" sound. At first I thought it was the slipper slipping too much. But it had plenty of acceleration. So I guess this is the normal sound the buggy makes at high RPM? It sounds cool, just making sure everyone else is getting the same sound from theirs. Don't wanna smoke the slipper pads! My nut is flush with the end of the threads, and I'm using the heavy clicker spring with the nut about one thread out from flush.
#4145
I liken the sound to that of a turbo when it is ripping down the straight.
#4146
In my opinion, I felt that with the front sway bar it gave the buggy a more planted rear end. It felt like I could carry more speed into and out of the corners. I give the white front sway bar a try and post your findings with it.
#4147
Trader Rating: 27 (100%+)
#4150
BTW I TQ'd and backed it up in the main tonight. Took the 8 week series in a tight battle. The 22-4 took 1st and 2nd on the podium. The only 2 TLR 22-4 kits in the house to. I am not changing a thing on my set up till I get to try the new cab forward. I think it will be the icing on the cake for me.
#4151
Un4racing, where abouts u suggest on picking up the new cab fwd bodies.
I am pretty noob to RC and picked up a 22-4 along with a 8ight-t 2.0 and have enjoyed driving it in practice and the look of the 22-4 already, however I have yet to race it yet.
I am running a 6.5t tekin gen 2 motor and a Castle Mamba Max Pro esc. I am wanting to go with a new esc, but this is an esc I have had prior so didn't have to pay anything for it.
If you could give me any suggestions on what motor/esc u reccomend for this lite beast that would be perfect.
Thanks in the meantime.
#4152
Thanks for sharing your knowledge and tips UN4RACING!
Here is your setup:
Here is your setup:
#4153
http://www.horizonhobby.com/products...22-4-TLR330003
Motor.... I don't know if I could ever run anything but a Reedy its all I run and I love them. I pretty well have just stuck with them tried and true. Before Reedy I ran Novak motors loyally.
As for ESC in todays market I would have to say I want the RSX pretty bad since its release and will soon to be getting one. I have had a lot of victories with the RX8 series and the RX8 Gen2 series and motors in 8th scale racing. The RSX has a 7.4 BEC option for high voltage servo options. You can flat out tune them in with the hotwire (30 bucks)to any track or section of a track precisely the way you want them. Tekin is at the top of my list for ESC's and there motors are second to none.
Other than that the Orion R10 would be nice 2nd choice. They are a solid ESC and have gained a lot of customers over the past couple of years. The Orions are solid but the tuning box is a rip off in my opinion. 70+ dollars for a tuning box is just bull crap. So I would have to give Tekin the nod for ESC's. State of the art with more versatile tuning options. Tekin is in warp speed ahead of everyone with there hotwire options, Phone and computer capable now. I may even be running the new RSX this week end.
I was running the Orion after the blow out ESC's LRP was putting out. Man they were a great ESC for years and all I ever ran. But they had a serious problem with quality for some time. Its put the hurt on there customer base.
Any hoot they came out with the LRP Flow and I thought man I just have to give them another shot. I like the brakes on the LRP's. Sadly though I hate it. I wouldn't recommend it at all. I hate to be to harsh cause its working great in blinky mode but it really lacks adjustment and each adjustment is weak and I really can't fine tune it like a Tekin or Orion.
I have ran others like Speed passion and Novak. So I have had a lot of ESC experiences. And there are some budget ESC out right now that are gaining in popularity.
#4154
It looks so much more pro than a pic of a set up sheet.
Thank you sir!
#4155
Okay show Off how the heck do you do that... I can't flipping figure it out. I hope I meet you some day so I can buy you a soda pop. I am just gong to bookmark this page right now. Arno sent me an editable one the other day and I am baffled. I have given up before I pull all my hair out. GRRRRR! I am going to have to hit someone up at the track and see if its me or this computer.
Thank you sir!
Thank you sir!
Hey UN4RACING.
Thanks for taking the time to post your set up. It is appreciated.
And congrats on your series win. I need to try your set up to see if it helps me at all.
Thanks again.
Tom
