TLR 22-4 THREAD
#3451
Ok guys , looking for some input , i set up my car with the JR Mitch setup and I am struggling to get rear traction and the car just will not hook up at my track , i am considering taking the sway bar off and going back to the box stock setup , There was another 22-4 running box stock last night and the car looked much better than mine on the track , Your advise and opinions would be appreciated , thanks . BTW, the track is a small 40x 60 layout , smooth , Med -Low bite top soil. here is a quick vid of the track with 2WD buggie running:
+ YouTube Video | |
#3452
#3454
Well, the D-F setup was a little loose out back for me so first I put a little bit thicker oil up front. That helped some. Then I went to the lighter swaybar and that helped too but I want a little more (darn my car has a lot of steering!). So I'm going to a little longer and higher rear camber link. I'm also going to try the longer and lower one but I haven't been able to get to the track and try either out yet. Unfortunately, after next week, our track closes for a while, probably a month then will be open for 2 months (crossing fingers) or could be closed until next Sept/Oct (it's also another business).
#3455
Maiden Voyage this week.
From what I read, the front A Arms and Hinge Pins continue to have issues with no TLR solution yet. As for hinge pins , is the best alternative the scte outer hinges (part # TLR233002)?
Other parts/upgrades needed:
TLR334009 — Steering Bellcrank Set Alum 22-4
TLR334012 — Servo Horn 25T Alum 22-4 (for SAXOX)
TLR234013 — Front Arm Set 22-4
TLR234021 — Shock Tower Set 22-4
Anything else?
Anyone have AMAIN codes?
Anything else?
#3456
Anything else?
Anything else?
http://www.amain.com/product_info.ph...-Shock-Shaft-2
The hinge pins you mention I believe are either LOSB4109
http://www.amain.com/product_info.ph...n-Set-10-Ten-T
OR TLR6080 http://www.amain.com/product_info.ph...inge-Pin-Set-6
I just recently (yesterday) ordered a 22-4 and also purchased the TLR6080 hinge pins. Looking forward to my build next weekend
Codes:
1430C1 (spend $150 = -$12.50)
1430C2 (spend $250 = -$25.00)
1430C3 (spend $750 = -$75.00)
#3457
#3459
What tires/compound and inserts are you running?
Try this set up. Last night myself and another 22-4 finished 1-2 in quals and on the podium. This set up was a lap on the field in quals and the main all night long. Then we had a team race. While my partner was throttling the kit I steered. We were again a lap on the field in the main. Medium bite track.
If you take the time to try it let me know how it works.??
This set will give you great on and off power steering.
But start this set up with one difference. Run the front lower shock position on the inner hole of the a-arm. If you like it drive it. If not move the front lower out and it will hair pin turns faster and give you more on power steering.
Not sure if you have any but the tires are the key to any set up. but any other tire may actually make it better?
#3460
Here's some positive feed back. And it was all on RC Live. Oh yeah.
Last night myself and another 22-4 finished 1-2 in quals and on the podium. We were a lap on the field in quals and the main all night long.
Now hear this! Big grin racing>>>>
We had a team race. While my partner (the only other 22-4 driver) was throttling the kit, I steered. We were again a lap on the field in the main.
Only thing breaking was the competitions ego's. we blistered some fanny's last night.
#3461
Well I went to the feb fallout in ky ,,it's a Capet/felt track.. I wasn't going to race it at first because I had no spares and it being a big money race..but after breaking the diffs in imhad too.this car was so smooth,and like a touring car as well..X-rays have been dominating there.i set tq and ended up putting 2 laps on the normal winner there..was running pretty much box setup only with front and rear yellow swaybars ..I'm loving this car
#3462
#3463
#3465
