Hot Bodies D413 1/10 4WD Buggy
#6992
#6993
I honestly have not tried a pinion that big. but, also keep in mind wheel slip. SRS I have little to no wheel slip. When I run a different track my temps go up 30deg. I was just trying to get you an idea of where to start. I am also not using any motor timing, as boost makes things run cooler. if you need to be blinky, you will need to turn the timing up some.
#6994
#6995
hey i run a tekin 8.5 20 boost 10 turbo . 28 pinion the car is a missile comes of the track at about 103 after 10 min of run . no wheel spin
#6996
forgot 10 on the drag-brake .
#6997
Springs
Ran the Gunsmoke setup at a fresh layout at LHR. Like it, ditched the stock springs for the kyoshos.....night and day better.
#6998
#6999
#7001
Correct. Referencing the setup conversations previously, kyosho springs being from the reedy setup. Further inferring; save time and trust these springs, or you'll need to chase something else that works. Chasing is frustrating for guys that want to perform on the track with what limited time and knowledge they have.
#7004
Any good recent set ups for indoor clay ?
#7005
CARNAGE !!!
Indoor carpet racing we have a table top setup in the corner on to the straight that you can cut from the take off to the landing and kinda came in a little hot and smoked the cinderblock building wall at about 1/2 throttle... lol ..
Expensive break... Technically I could still race the first hole is still useable
