Hot Bodies D413 1/10 4WD Buggy
#6245
Can someone explain these arm insert things in depth? Would be much appreciated! Thanks!
#6246
they stiffen the arms for differet degree of traction and how you want the flex to feel
soft to stiffest.
unglued plastic
glued plastic
unglued carbon
glued carbon.
soft to stiffest.
unglued plastic
glued plastic
unglued carbon
glued carbon.
#6247
i noticed the grining two. i have a feeling i will have to replace the hangers because of wore down after a while of racing.
and i got me a bag of m2 nuts because i have stripped a couple of them putting them on when making setup changes. wish they would have used m3 nuts here.
#6248
Has anyone noticed that the front out drive hit the arm inserts when the shock are fully compressed.
#6249
When I compress the arm all the way up, it does not hit the outdrive. I use the middle top shock mount and the outer lower mount. But saying that, I do have marks on my arm from it hitting the outdrive. I think it comes from those less than ideal landings. The arms seems to bend slightly and hit the outdrive.
#6251
I don't think the line of the eyelet should matter. Your shock should stop when the retaining cup hits the bottom of the shock body. So no matter where your screw it in, top line or bottom line, it would be the same. All eyelet settings should end with the same length with the shock compressed. I read somewhere on one of the TLR threads, if the piston hits the shock cap internally, then that is a bad thing. And I don't think the lowest line gets you to that point. Only an externally limiter would properly restrict the arm from hitting the outdrive.
So probably too much travel on the shocks. But I bet it is also dependent on shock mounting location.
#6252
Something I do on my 410 is to run Button Head screw close to key areas. For instance, on the front kick up I run Button Head screws and they keep the chassis and suspension hangers from taking as much abuse and enduring more wear than with he countersunk screws. I also run 2 of them in the rear.
I do the same on my PRS1 on both ends and it helps protect parts and prolong my having to dip into the wallet. Another thing I run on ALL my cars are the Durango Shock Bumpers.
Tracks need to stop this artificial surface nonsense and get back to real dirt tracks. Red Clay is the perfect compromise between all out dirt and completely artificial.
It's abrasive to some degree and can become hard packed, but still playable enough that it won't grind parts down to nothing.
#6253
Sorry, I was talking about the suspension hangers. What the different dots mean and the different sims do.
#6255
