TLR 8IGHT E 3.0 THREAD >
Like Tree2Likes
Old 05-12-2013 | 12:14 PM
  #76
XXXDad's Avatar
R/C Tech Elite Member
Thumbs up I had fun with the Build...
Originally Posted by smy_dog
hi guys im just after your opinion here...
i have a 8ight E 2.0 which is my first buggy and i am looking to upgrade. i am leaning towards the 3.0 as i am a losi fan and have a buttload of spares that can be used on the 3.0
some of you seem concerned about the losi being over priced and also using the old conversion kit.
it is obvious that losi are a more expensive kit anyway so is it seems very unlikely that the price is going to drop or when they bring out the E kit it will be that much cheaper than buying one now and converting?
also when they bring out the E version would it really look,handle or even use any different parts than the nitro kit apart from the conversion? they havent done so in the past so why would they change now?
any reply would be great as i am no expert when it comes to the technical side of things and trying to gather a bit of information before i spend the money.
cheers, peter
The New TLR is all about Quality and Fit. Get one and never look back!
My setup is 5/5/3- 32.5 F/27.5 R
Only upgrades so far are TLR Alu servo Horn , Lundsford 5mm Titanium Turnbuckles ,and some DE mudguards.
It will get the Bulldog 2012 E Body with my own Paint.....
XXXDad is offline
Old 05-12-2013 | 01:30 PM
  #77
Hey I'm very excited about this buggy! I cannot wait to see what they will do when they release an e-version. Do you think they will build a separate chassis?
-Zack
kcaz25 is offline
Old 05-12-2013 | 01:53 PM
  #78
XXXDad's Avatar
Smile From what I hear No plans for dedicated E Buggy
-Zack
Don't hold your Breath....
XXXDad is offline
Old 05-12-2013 | 05:23 PM
  #79
Brian C.'s Avatar
Originally Posted by guss2009
Hey guys I have 2 losi 8ight 3.0 and I'm turning one into electric but I have a few questions and hope you guys can help me. I have the Tekin Rx8 combo 1900kv and installing the losi 8ight electric conversion kit all new. I also have the Gens 5000mah-40c-14.8v-4s1p hard case lipo battery. I'm new to electric and would like to try it out. My questions are
1. On the electric convention is there any mod I need to know or do I install everything that's in the package?
2. Do I use the 48t aluminum losi center spur gear that came with the buggy or should I use the one that came in the electric conversion package?
3. What pinion gear should I use? Package came with 2 different pinion gear.
4. Is there a soldering iron that I can buy and is not expensive that would do the job to solder the wires like the hakko or trakpower stations? I don't solder much so I don't think I need a soldering station unless its recommended.
5. What wire gauge should I buy? Tekin only sends 3 wires. I need the motor wire.
Sorry for all these questions. I want to get everything right and not mess the tekin combo up. Links, pics and any tips would be appreciated. Thanks for your help.
Originally Posted by ChrisWolfson
1. everything in the package is used. No mods necessary.
2. use the plastic 45t spur that comes in the conversion.
3. you get a 15 and a 16 tooth. generally the 15 is good in most places.
4. get the orange weller iron. cheap and HOT. i've always used it. here's a link - http://www.amainhobbies.com/product_...FQTd4AodhlcApA
5. you should have enough wire to get it all done with what they send, but if you need more, buy 12 gauge.
Good luck!
The 48t will burn your motor, because the 48t is so big that it hits the chassis and gets stuck just experienced it today lol. My 45t was no good and did not have another an the 48t almost burned my motor.
Brian C. is offline
Old 05-12-2013 | 06:04 PM
  #80
XXXDad's Avatar
Wink Use the 45T or 44T Sprocket
14-15-16 Pinion depending on your KV...
Oh.... and the Support....
that goes under the rear of the motor> TAKE IT OFF
XXXDad is offline
Old 05-12-2013 | 06:09 PM
  #81
Brian C.'s Avatar
Did you quote the wrong person?
Brian C. is offline
Old 05-12-2013 | 06:56 PM
  #82
XXXDad's Avatar
Wink Do you use the Spacer?
For some motors the spacer fits, but not all.
^^ for the other guy
If you use the Spacer then.......
XXXDad is offline
Old 05-12-2013 | 09:55 PM
  #83
smy_dog's Avatar
does the nitro body fit with a 4S under it?
smy_dog is offline
Old 05-12-2013 | 11:45 PM
  #84
smy_dog's Avatar
OOOPS!!! i just bought one!
smy_dog is offline
Old 05-13-2013 | 03:28 AM
  #85
Brian C.'s Avatar
Exclamation
The nitro body sits way to low!!! The body will fit but will get extremely tweaked when you put it on, because of the 4s.
Brian C. is offline
Old 05-13-2013 | 04:09 AM
  #86
smy_dog's Avatar
cheers mate! lucky im a thinker and bought a proline bulldog body just in case haha!
smy_dog is offline
Old 05-13-2013 | 11:25 AM
  #87
Question for you guys. I just bought the 3.0 shocks to upgrade my 2.0 electric . When I received the shocks both packages say 16mm FR Shock Set,Complete: 8b 3.0 . The part number on the packages is Tlr243021 and Tlr243022. Now I don't want to open the Tlr243022 package which is suppose to be rear shocks and have them be fronts . I hope the label was misprinted as far as both saying Fr shocks. Unless there both the same size and are used fr and rear.Anyone else run into this. ?
Losi57 is offline
Old 05-13-2013 | 11:32 AM
  #88
Brian C.'s Avatar
Thumbs up
Wow smart thinking lol.
Brian C. is offline
Old 05-13-2013 | 11:43 AM
  #89
Package is transparent, just meassure the shock shells via packing. Rear should be little longer then front.
herK is offline
Old 05-13-2013 | 12:47 PM
  #90
Brian C.'s Avatar
Exclamation
Does any one know if there will be a 8ight T 3.0 soon to be release, because the 2.0 is discontinued?!?!
Brian C. is offline
