Team Associated B4.2 Thread >
Like Tree4Likes
Old 02-03-2013 | 08:55 AM
  #1126
F18engineguy's Avatar
Originally Posted by Tony Vega
No they still rub. You need to mount the carbon tower on the backside of the hub carrier and use an ASC6277 ball stud and space it out with a 2mm spacer (ASC31326). It angles the camber link back slightly and there is no rubbing even under stress when the arm flexes.
Thats too bad, big disappointment. not sure why they could not have changed the geometry of the rear tower slightly to avoid this.
F18engineguy is offline
Old 02-03-2013 | 09:03 AM
  #1127
Tradin Paint's Avatar
Originally Posted by Cridd
Yes bad glue is bad.
Most like the clean look and run through tower.
I like to run them on the outside of the tower and then zip tie them to the tower. This way if you need to change the tower you don't need a soldering iron. I do run the sensor wire through the tower
Tradin Paint is offline
Old 02-03-2013 | 09:07 AM
  #1128
sunco1's Avatar
Even better, pm me if you get them done.
I will take one to if you do them
sunco1 is offline
Old 02-03-2013 | 09:17 AM
  #1129
No issues with my 4.2.
I do have to say that aluminum shock mounts on aluminum shock caps is unbelievably stupid. I put the old school plastic shocks mounts on.
And IMO, hexes on a buggy is silly. I put the old school stuff on.
Manning is offline
Old 02-03-2013 | 09:19 AM
  #1130
Wild Cherry's Avatar
Tech Legend
I can deal with 2 little .030 shims .....
Wild Cherry is offline
Old 02-03-2013 | 09:20 AM
  #1131
Dork Missile's Avatar
Originally Posted by snaketaco
This is what my awesome girl went out and got me today!
Does she have a sister?
Dork Missile is offline
Old 02-03-2013 | 09:28 AM
  #1132
vito's Avatar
ill up a pic win i get home to night you guys will pick out the bo bo i made
vito is offline
Old 02-03-2013 | 09:49 AM
  #1133
07Forester's Avatar
My wife is the same! She's to blame for ATLEAST half of my addiction. Most recently she got me 2 servos and 2 rx's for valentines day.
07Forester is offline
Old 02-03-2013 | 09:55 AM
  #1134
air8's Avatar
For those with shock caps not fitting over the bushing....has anyone measured the parts to see where the difference is????
air8 is offline
Old 02-03-2013 | 10:37 AM
  #1135
GizmoTLR's Avatar
no offense but most of the people on the previous page need some grammar classes
so u pretty much have a 4.1 with VTS, alum steering rack, and 1/2 of the BB shocks
GizmoTLR is offline
Old 02-03-2013 | 10:55 AM
  #1136
rider313's Avatar
rider313 is offline
Old 02-03-2013 | 11:23 AM
  #1137
Eli's Avatar
Eli
For the guys complaining about the rear camber link rubbing on the shock are you guys running a spacer on the lower shock rod and are you guys using the shorter ball stud on the hub side?
Im currently running no spacing on the tower just some dremel work like the .2 tower has molded in, 2mm on the arm to space the shock out and the shorter ball stud on my hub and dont believe i am experiencing any rubbing issues even with the b44 arms that flex more. Theres a reasonable amount of clearance between the spring on my big bores and the camber link.
Eli is offline
Old 02-03-2013 | 11:24 AM
  #1138
Wildcat1971's Avatar
Originally Posted by Jmuck69
He used a cut down rear T plate. I believe using a plastic T plate is better since it will not stiffen the chassis and plastic would have minimal influence.
I talked to some guys last night that ran the reedy race. they said cav just mounted it to the strap.
Wildcat1971 is offline
Old 02-03-2013 | 11:27 AM
  #1139
BLbound's Avatar
IMHO I think hexes are a good thing. I've seen guys strip out the pin style rear rims, hexes eliminate that possibility.
BLbound is offline
Old 02-03-2013 | 11:29 AM
  #1140
I dremeled my towers and use .09 on the bottom and I had a tiny little bit of rubbing with the b4.1 rear arms and lunsford turnbuckles (they are thicker). The b44 rear arms are stiffer right? So maybe no rubbing if I got those.
