Team Associated B4.2 Thread >
Like Tree4Likes
Old 10-28-2013 | 08:05 AM
  #10846
Wild Cherry's Avatar
Tech Legend
Originally Posted by motorhead68
WHAT SPRINGS ARE YOU RUNNING ????
Green front
White rear
Wild Cherry is offline
Old 10-28-2013 | 08:53 AM
  #10847
Wildcat1971's Avatar
I know there is a lot of mid motor craze going on. But, I have been really curious as to weather MM would work on my local track. Then this weekend, a sponsored and fairly fast AE driver showed up to run my track. I was thinking, cool I can see the c4.2 in action. But....He pulled out his RM can and never even tried the MM car. So in short, I am pretty confident that my track would not be good for MM, because even the sponsored guys wont run MM there. One of the local TLR guys also has both the MM and RM car at the ready, but run RM. So before you go MM, and spend all of that cash, make sure you have a track where MM would be beneficial. I personally think if you are to only own 1 car, RM is the way to go on most tracks. If you race a lot and travel a lot, then buy 2 cars. One for MM and one for RM.
Wildcat1971 is offline
Old 10-28-2013 | 09:04 AM
  #10848
Grasschopper's Avatar
Yea Alex Miller Lapped the field in 2wd Mod Buggy at Bumps yesterday running a B4.2. Mine felt dialed...just wish I could drive better.
Grasschopper is offline
Old 10-28-2013 | 09:12 AM
  #10849
Tech Legend
Ran with a Team mate with new Serpent rear motor all day .
Conclusion ???
Rear motor is dead ....
Went to track this week end that has a reputation for rear motor ,.
MM had plenty of grip & we will change all of the rest to MM
after another race or two ....
Old 10-28-2013 | 09:29 AM
  #10850
DanielC.'s Avatar
Agreed, one car in each configuration is the way to go. Why fight the setup to make MM work in a lower traction condition, when the RM cars are going to have the advantage, and vice versa?
Was testing my x factory cubed in a slick condition compared to the b4, and to me it's no contest. The mid can run the same lap times but you're fighting the car from stepping out, which makes it much harder to be consistent from lap to lap.
DanielC. is offline
Old 10-28-2013 | 09:32 AM
  #10851
rc car guy's Avatar
I didnt belive it either but I havent had a chance to try the a hub the 2nd race the fast guys did the shaved brace with tthe c hub and I did that and it worked I know its suppose to make better conerner speed and better traction without increasing it just better
rc car guy is offline
Old 10-28-2013 | 09:35 AM
  #10852
rc car guy's Avatar
That may be true on dirt but if you are running on a high bite surface its the opposite more caster is more aggressive and less caster is easier to drive and I have personally done that test Friday
Old 10-28-2013 | 09:43 AM
  #10853
carcrusher46's Avatar
Not sure how you came to that conclusion but something wasn't done right. Less caster will always be more responsive no matter what the surface. Running off-road on carpet, I used to run 20° caster blocks with in-line axles on my old T4 so that it would be the most instantly-responsive vehicle possible. Running 25-30° of caster, the truck just refused to turn on-power because there was so much traction.
carcrusher46 is offline
Old 10-28-2013 | 09:50 AM
  #10854
rc car guy's Avatar
I swapped 30 deg caster blocks becausw It was traction rolling in the front to the 20 deg caster blocks and its really easy to drive and has plenty of steering this is gaurnteed the most traction you have ever ran on so in short at our track many things that should be one way are the opposite it had been this way since about 3-4 yrs ago and thats why I said what I did about the onroad carpet
Old 10-28-2013 | 09:58 AM
  #10855
1mrdad's Avatar
The MM craze is going on at my track and the fast guys seem to be switching. That said my blinky 17.5 B4.1, my son racied it in 2wd mod in blinky mode. His laps and times would have been TQ in blinky by .01 shy of a full lap ahead of the next car (a MM Losi) and won the main against all of those MM cars.. I am 2 secs /lap slower than my son driving the same car. IMHO, MM/RM unless you are one of the regular top 5 guys in your class, save your money and practice practice practice.
1mrdad is offline
Old 10-28-2013 | 10:13 AM
  #10856
ChrisAttebery's Avatar
Is that at Dutra Farms still? I've been there a couple times but I can never get anyone to call me back to reply to my questions about it. Can you email me any contact info you might have?
Thanks,
Chris
Originally Posted by Crash Test Dumy
I will run at NorCal, but mostly at our club in Watsonville. Here's a little vid of our new track
http://www.youtube.com/watch?v=N-xsrE08yeg
It's pretty sweet, now that we've got the roller going. This new track is what has made me want to try a 1/10 2wd buggy.
Take a look and let me know what you think.
Brian
ChrisAttebery is offline
Old 10-28-2013 | 10:52 AM
  #10857
racer1812's Avatar
Super Moderator
Conclusion ???
racer1812 is offline
Old 10-28-2013 | 11:10 AM
  #10858
@WC: can you post a vid of you running the centro in real low grip conditions against a rm?
Cody227 is offline
Old 10-28-2013 | 11:11 AM
  #10859
Conclusion ???
Yup, Im keeping my B4.2 stock RM (still fighting with setup grrr, too much initial steering) and will be converting my Durango to MM. But I am one of the slowest guys in stock buggy locally so its not like switching to MM will instantly make me a better driver.
fivepointnine is offline
Old 10-28-2013 | 11:13 AM
  #10860
lol, too much initial steering.... you own a b4, what did you expect, lol. try green springs up front. It calms the car down a bit.
