Team Associated B4.2 Thread
#9350
I wonder if you could make the JConcepts one work on the front: http://www.jconcepts.net/store/index...roducts_id=696
Maybe use the rear bars on the front mount to clear the shocks? Not seen this before, just a thought.
This IS a front AND rear sway bar. I don't understand your comment?
#9351
Maybe George is blocking me? Honestly I don't think so I just think the shock talk is more interesting and my posts are getting swept away. I'm gonna keep trying though. I was going to PM but it appears you have it turned off.Trying to confirm which AVID Triad setup you are using....again I think it's white on the trany side of the spur, then red in the middle and white on the outside.
#9352
Try reading back 1 page, or 2, or 3, or every other page for the last 3 months. You might find something that way
#9355
Grass Hopper , sorry thought I covered question for you and everyone .
Had a buddy last night install the RED Avid pad and he was all smiles .
Were using RED cus on the ramps before jumps the slipper would slip a bit too much when you throttled up to clear .
#9357
I've been running all white and picked up a set of the reds to try but I haven't gotten around to it yet. This past race weekend traction was so poor I decided to loosen my slipper for the main and did it too much and I was toast in the main, it was slipping way too much. I have at least one jump that your description is perfect for.
#9358
You did...I missed it. So do you think this is a good option for both stock and mod racing with the B4? I have a car for each class now and don't have time to do proper testing as the closest track is 108 miles from me. Basically I take my chances running what others say works and making small adjustments at the track throughout the race day if something is wildly out of whack.
Stock can use the mod even more sense 17.5 is all torque and can slip just as much as a 7.5 does ...
4Likes
