Team Associated B4.2 Thread >
Like Tree4Likes
Old 08-02-2013 | 05:15 PM
  #7591
Matt Trimmings's Avatar
Originally Posted by Wildcat1971
Anyone using tuning rotors with the reedy sonics
Never felt the need with the reedy's...they were always pretty good out of the box.
Matt Trimmings is offline
Old 08-02-2013 | 05:32 PM
  #7592
Looking for a new 17.5 I am running an orionr r10 pro race version in blinky.
I am looking for a super fast 17.5 other thant he d3.5
Is teh revtech killshot with a high torque rotor as fast as a d3.5 ?
xTotalghost is offline
Old 08-02-2013 | 06:10 PM
  #7593
JBrad's Avatar
Anyone run at wcrc in so cal? Looking for a good base set up.
JBrad is offline
Old 08-02-2013 | 06:14 PM
  #7594
Suspended
Originally Posted by Matt Trimmings
Do you have the WC kit? if so then no, it is the same +8mm chassis.
Well idk lol it just says factory team on it lol it has a blue motor plate and some hefty looking Cvds and all rpm and blue turnbuckle rods and cf batt strap and threaded shocks and a blue front chassis brace, that's all I kno that are different than an rtr!
theblitzkidd is offline
Old 08-02-2013 | 06:15 PM
  #7595
rcman182006's Avatar
I'm running a standard RevTech 17.5 on a Tekin RS, it doesn't have near the explosive power as the D3.5 but it feels a lot smoother, any motor is fast with the proper gearing and buggy setup
rcman182006 is offline
Old 08-02-2013 | 06:27 PM
  #7596
does the center of your chassis (on the underside) look like it has about an 8mm strip added? Does it have the circular mold release plug on it (about the size of a nickel)?
Old 08-02-2013 | 06:55 PM
  #7597
Stanfsu's Avatar
Will the b4.1 bodies work on the B4.2?
Stanfsu is offline
Old 08-02-2013 | 07:05 PM
  #7598
As long as its a +8mm body it should fit
Old 08-02-2013 | 07:07 PM
  #7599
YankeeFan123's Avatar
Front:
24 mm ride height
Inside top of shock tower
Outside bottom of shock
1 mm washer on front ball stud
30 deg caster blocks, inner hole (I believe)
1.6 AE pistons
30 wt AE oil
Green AE springs
Rear:
Inside bottom of shock
0 washers underneath rear ball stud
A hubs
1.6 AE pistons
27.5 wt AE oil
Green AE springs
Other:
No weight by servo
7g in each rear triangle
My set up for there..
YankeeFan123 is offline
Old 08-02-2013 | 07:54 PM
  #7600
Suspended
It does not have to be +8mm for it to fit. The old B4/B4.1 body will fit the WC and B4.2.
Team G Racing is offline
Old 08-02-2013 | 07:56 PM
  #7601
Wildcat1971's Avatar
Define fit?
Wildcat1971 is offline
Old 08-02-2013 | 08:38 PM
  #7602
BIGSKI15's Avatar
I know this is a preference but how do you like your dead band width set? I have tekin rs' and pros and I set it at 5. I drove someones car tonight who had his set at zero and as soon as you touched the throttle, it was going.
Just curious as to how people like theirs or pro/cons of having it set that way.
BIGSKI15 is offline
Old 08-02-2013 | 08:42 PM
  #7603
I run mine in the middle setting.
Does anyone here charge their lipo pack WHILE the esc is plugged into the pack with alligator clips? I saw a pic of cav doing this. this is not something I need or want to do, but I am curious as to weather this is bad for the esc. I smoked an esc back in the day when we used to solder our packs in and I didnt want to desolder the pack for charging.
Old 08-02-2013 | 08:56 PM
  #7604
Skillz_B's Avatar
I have seen that pic of Cav as well, I would never do it, but I pay for my equipment.
Skillz_B is offline
Old 08-02-2013 | 09:50 PM
  #7605
mingoglia's Avatar
Even if it's a standard 4.1 and not a +8 it fits almost as well. Just a 8mm gap just behind the suspension arms. Out of my 5 or 6 bodies I run I think only one of them is actually a +8 body. You have to really be looking and know where to look to even tell.
mingoglia is offline
