Team Associated B4.2 Thread >
Like Tree4Likes
Old 01-10-2013 | 07:29 PM
  #91
07Forester's Avatar
Matt, Wildcat, pm me with any other info you've got.
Gonna start working on a few things
07Forester is offline
  #92
Wildcat1971's Avatar
I would also put a link top the b4.2/b4.1 setup sheets. The kit setting from the manual looks really good. Mainly the tires, shock package and hubs change for most of us. You might want to put the popular shock packages up, or more specifically the 1.7mm shock setup that guys are running, since the 1.6 shock package is in the manual. Maybe speak to what is gained and lost between the 1.6 and 1.7 packages. We actual;ly dont have a ton of MOD's anymore. The hex conversion, the alum rack and the 3 disk slipper are all included now. Shaving the brace might be the only mod left, lol. We dont even have to dremel the tower for the BB anymore.
Wildcat1971 is offline
Old 01-10-2013 | 07:32 PM
  #93
CHIZZLE's Avatar
I can't believe I gotta keep up with two threads now. Stupid.
CHIZZLE is offline
Old 01-10-2013 | 07:34 PM
  #94
I almost forgot. No one has mentioned this much in a while, but grub screwing the rear hubs. Someone brought it up a few days ago. What bit and tap to use and such
  #95
Originally Posted by Zachfeen
Damn I have a brand new B4.1 worlds sitting here unbuilt. Now must decide whether to return it and wait, or build and upgrade as I go. Financially probably smarter to return it and wait but I wanna race the thing. The only thing that really seems necessary is the big bores
LOL! Me too! I knew this was gonna happen. My poor WC is loose, I mean loose, so I decided to get a new WC kit and purchased the big bores separate. I have been waiting for this release and waiting to upgrade my shocks but couldnt wait anymore and of course the "new" kit is in a press release 4 days after I bought all the other stuff.LOL!
bambambennett is offline
Old 01-10-2013 | 07:40 PM
  #96
lbckevin's Avatar
Nice
lbckevin is offline
Old 01-10-2013 | 07:47 PM
  #97
2canSAM's Avatar
R/C Tech Elite Member
Gearing and track size would be cool, link to starting setups like Chad Due Indoor and Ryan Cavlieri All Indoor Track, mods such as grub screw rear axle, shaved u brace, maybe some of the more common tuning options. Since they would technically not apply to the "new" car I don't know if shaved tower for big bores, gluing the steering rack, V2 Big Bore, etc should be listed or not.
2canSAM is offline
Old 01-10-2013 | 07:51 PM
  #98
Tradin Paint's Avatar
+1 they seem pretty determined to have 2 threads on the same car. Thanks Forester!
Tradin Paint is offline
  #99
andrew-01's Avatar
Care to elaborate? In the mean time, I'll sort through the B4.1 thread and look for mentions of this. Thanks
andrew-01 is offline
Old 01-10-2013 | 07:53 PM
  #100
Matt Trimmings's Avatar
Some tap a thread into the rear hubs to 'lock' the hub to the hinge pin with a setscrew, takes a little bit of slop out of the rear end. Nobody likes a sloppy rear end.
Matt Trimmings is offline
  #101
rednck21's Avatar
If I have a b4.1 now with all the current upgrades, and I decide to buy the new 4.2 will the same setup work or will I need to start over?
rednck21 is offline
Old 01-10-2013 | 07:55 PM
  #102
2canSAM's Avatar
You basically tap the the Aluminum Rear Hub with a grub screw so you can tighten it against the rear hinge pin to help with some of the slop. It is listed somewhere in the B4.1 thread but I'll see if I can find it. If you have seen a TC3 or TC4 Rear Hub it is the same concept.
Click here for an idea of it
2canSAM is offline
Old 01-10-2013 | 07:56 PM
  #103
andrew-01's Avatar
I wasn't aware of the terminology used, seems like a pretty standard mod regardless. Thanks for the clarification Matt.
Old 01-10-2013 | 07:57 PM
  #104
Wow! I have more posts than Wildcat?!
Old 01-10-2013 | 07:58 PM
  #105
05PSD's Avatar
Exactly. More than half the people have all the upgrades anyways. Lame.
05PSD is offline
