Team Associated B4.2 Thread >
Like Tree4Likes
Old 06-23-2013 | 06:20 PM
  #6346
Finished painting it up today. Ive been out of the hobby for year and a half and look forward to getting back to the track.
DG Designs is offline
Old 06-23-2013 | 07:28 PM
  #6347
DLF
My apologies if this has been brought up before.
I just rebuilt my shocks for the first time since the original build. If built per the manual, I get "negative rebound", for lack of a better term.. In otherwords, at full extension, the shocks want to compress on their own. I corrected the problem by staring over but, this time, not compressing the shock all the way before screwing in the bleeder screw.
Did AE intend for the shocks to do this on their own?
DLF is offline
Old 06-23-2013 | 07:49 PM
  #6348
Kellen Guthrie's Avatar
This is a good thing. Rebound is when the shocks are fully compressed and the piston wants to move down. I always run my shocks with zero rebound.
Kellen Guthrie is offline
Old 06-23-2013 | 08:05 PM
  #6349
Skillz_B's Avatar
I had the sae thing, if you work the piston back and forth they will equalize, you want zero rebound.
Skillz_B is offline
Old 06-23-2013 | 08:59 PM
  #6350
Waflet's Avatar
Hideeho
Also, after doing this, re-bleed the shocks. You may have to bleed them a third time. If you take your time & do it right, 2 bleeds almost always does the trick. Don't forget to check them at the track as the day warms up & possibly bleed them after a few runs.
Waflet is offline
Old 06-23-2013 | 09:25 PM
  #6351
Skillz_B's Avatar
Originally Posted by Waflet
Hideeho
They were even smoother after bleeding them a second time, I have noticed a little oil around the spring cup, and on the rod end on hot days, anyone else have that happen?. I used shock pliers when I built the shocks and was really careful, I figured the shock oil is thinning due to high temps. I have read the Aka front wheels dont work with the Jconcepts axles, if thats true are there any that work better?
Skillz_B is offline
Old 06-23-2013 | 10:00 PM
  #6352
elex300's Avatar
When you bleed the shock by pushing the piston to the top the shaft and piston take the space of the oil you bleed out. When you fully extend the shock shaft you create a vacumm effect so it draws the shaft back in. Its totally normal. Just build with 0 rebound and you are good.
elex300 is offline
Old 06-23-2013 | 11:24 PM
  #6353
so when there is "negative" rebound its called 0 rebound?
when i flip my car over (and the shock oil is going down) i can feel that there is air in the shock. like a little gap where theres no oil.
is that normal?
cos the shocks dont have a gasket under the shock cap. (cos of the bleed screw i guess)
the gasket's job is to compress when the shaft is compressed to handle the volume of the shaft, and if there is no gasket there is nothing to absorb the volume of the shaft.
ebay007 is offline
Old 06-23-2013 | 11:26 PM
  #6354
is that normal?
U can try running bladders in your shocks, they tend to seal better from air
zzztech is offline
Old 06-23-2013 | 11:30 PM
  #6355
you mean bleed cups?
can you give me a link to the product your talking about?
ebay007 is offline
Old 06-23-2013 | 11:42 PM
  #6356
http://www.tsrproducts.com/index.php...0001-12mm.html
Or look under Losi SCTE shock bladders, they "should" fit too
zzztech is offline
Old 06-24-2013 | 01:20 AM
  #6357
thanks man!
i happen to have a losi then t which have the same shocks and i tried putting the gasket in the ae shock and it works very well! i can adjust the rebound by opening the bleeder screw, compress or not compress the shaft and then close the bleeder screw.
ebay007 is offline
Old 06-24-2013 | 01:39 AM
  #6358
Skillz_B's Avatar
is that normal?
If there is air in your shocks you need to rebleed them, a little rebound on freshly build shocks is normal, they will equalize.
Skillz_B is offline
Old 06-24-2013 | 01:52 AM
  #6359
rebleeding isnt gona do anything.
the problem is that bleeding and fully compress the shock causes a vacuum action when the shaft "expends" so air is going in from the bottom cap.
if there was a gasket then it would absorb the volume of the shaft going in and out.
ebay007 is offline
Old 06-24-2013 | 05:12 AM
  #6360
elex300's Avatar
is that normal?
When you push the shaft all the way up and it does'nt come back out you have 0 rebound. These are emulsion shocks so a little bit of air is needed for them to perform properly. Watch the video on emulsion shocks. http://www.youtube.com/watch?v=IgLTY17vPHg
elex300 is offline
