Team Associated B4.2 Thread >
Like Tree4Likes
Old 06-24-2013 | 07:59 AM
  #6361
Waflet's Avatar
Hideeho
The 2nd (or 3rd) time you bleed, you are bleeding excess oil not air. AE shocks for the b4 series are emulsion shocks & WILL have air in them. Through repeated bleeding & pumping you will eventualy get your shocks to completely neutral rebound, no positive rebound (compress the shock & it is pushed back out) or negative rebound (expand the shock completely & the shaft gets pulled back in).
Waflet is offline
  #6362
Originally Posted by Skillz_B
Anyone running the Trakpower ESC or Motor, the new Car Action has a first look, but there isnt much info on them.
I won a 17.5 motor/esc Trakpower combo at a recent race I attended. I haven't used the setup much, but from playing with it one practice day.. ESC seems pretty smooth (probably couldn't even tell the difference between it and my Orion R10 pro). Don't like the fact that you cannot use a proigramming box or link to change settings- It all must be done via the esc.
The 17.5 motor wasn't blazing fast, but it got the job done.
rc10gt82 is offline
Old 06-24-2013 | 08:14 AM
  #6363
Originally Posted by ebay007
thanks man!
i happen to have a losi then t which have the same shocks and i tried putting the gasket in the ae shock and it works very well! i can adjust the rebound by opening the bleeder screw, compress or not compress the shaft and then close the bleeder screw.
Actually for really dead / no rebound you can leave the bleeder screw in the cap out. The hole will not leak oil. We do that in TC all the time
zzztech is offline
Old 06-24-2013 | 08:20 AM
  #6364
the incubus's Avatar
Touring cars only dampen a very small amount which is why it is ok for that application but off-raod buggies are vastly different and the shocks travel their full lengths repeatedly in remarkably quick fashion, thus shooting out some fluid should you leave the bleeder screws out. As well, the severe bottoming out would be a painful experience to endure.
the incubus is offline
Old 06-24-2013 | 08:21 AM
  #6365
This is with an uncut bladder, it will create a air tight seal around the shock cap when seated properly
zzztech is offline
Old 06-24-2013 | 08:24 AM
  #6366
OK that's different. LOL
Old 06-24-2013 | 09:01 AM
  #6367
does anyone know, how much kv the thunderpower z3r 7.5t has?
Cody227 is offline
Old 06-24-2013 | 10:03 AM
  #6368
Nicholas Muelle's Avatar
Is the 12mm big bore spring sets the same for both buggy and Short Course Trucks?
Nicholas Muelle is offline
Old 06-24-2013 | 10:12 AM
  #6369
i don't think so, SC shocks are usually longer
Cody227 is offline
Old 06-24-2013 | 10:23 AM
  #6370
MODELTECH22's Avatar
they are the same for buggy,stadium, 4wd, and sct. the lower spring retainer on your shock is longer on the truck, and shorter on the buggy, for the differance you need.
MODELTECH22 is offline
Old 06-24-2013 | 10:29 AM
  #6371
thanks, is it worth buying all of the shocks, like the medium, hard, and soft sets. or are there ones that you dont need?
Old 06-24-2013 | 10:46 AM
  #6372
Suspended
Depends on track conditions. Do you travel to other tracks where the surface is different? Usually the soft and mediums are nice to have.
Team G Racing is offline
Old 06-24-2013 | 11:00 AM
  #6373
Normally i dont. My main track is a medium to high traction surface with some triples. i have been getting higher competitivly and have been traveling more. what kind of conditions are the hard springs good for?
Old 06-24-2013 | 11:46 AM
  #6374
ya, i have just bought the soft front and rears and the medium hard and rear. I havent found a need yet for the hard frt and rear.
Old 06-24-2013 | 12:27 PM
  #6375
aeRayls's Avatar
Springs most likely used/needed:
Front:
Brown
Black
Green
White... *If you run on very high grip
Rear:
Green
White
Gray
aeRayls is offline
