Team Associated B4.2 Thread >
Like Tree4Likes
Old 06-06-2013 | 08:42 PM
  #5941
Venom1836's Avatar
What does the width of the rear of the car have on handling?
What if I remove the two thin washers behind the hex adaptor?
Venom1836 is offline
Old 06-06-2013 | 08:45 PM
  #5942
Wildcat1971's Avatar
Originally Posted by Blitzrockey
Which ones would be the best to use on a low traction track? Thanks.
A
Wildcat1971 is offline
Old 06-06-2013 | 08:47 PM
  #5943
what happens if you put your feet together and someone pushes you? now spread your feet 12 inches and what happens now? Roll sir, you will lean more or roll more with a narrow track. You will loose some stability, but roll more in the corners.
Old 06-06-2013 | 09:14 PM
  #5944
mingoglia's Avatar
If my feet were together and someone pushed me my right arm (and fist) would extend out very quickly to help "offset" my being off balance.
mingoglia is offline
Old 06-06-2013 | 09:34 PM
  #5945
Old 06-06-2013 | 10:11 PM
  #5946
Teambcw's Avatar
Teambcw is offline
Old 06-07-2013 | 12:19 AM
  #5947
Holmberg418's Avatar
C. Lower roll center.
A is to free up the car.
Holmberg418 is offline
Old 06-07-2013 | 12:57 AM
  #5948
Suspended
Those shims are only there to keep the hexes from rubbing on the bearings. If you think those shims are there as an adjustment, you are not good enough to feel even if they did change something. On the 22, the different thickness hexes were .75mm and 1.5mm wider, and only made a minor difference in handling. The only difference they would make would be if the removal of the shims caused enough drag to slow your car down so it will be easier for you to drive.
ifuonlyknew is offline
Old 06-07-2013 | 01:00 AM
  #5949
Skillz_B's Avatar
My used B4.2 only had the C hub towers, so I ordered a set of all the hub towers. This will leave me with a spare set oif C hub towers when they get here, if someone wants them all I ask is they pay shipping, or I will trade them for a wornout set of wheels n tires. I can not afford a full set of new wheels n tires right now, but I need to break in my diff, and do some initial setup stuff, they can be bald, I am only using them to tune some stuff.
Skillz_B is offline
Old 06-07-2013 | 06:17 AM
  #5950
I am pretty sure C raise the roll center and A Lower it.
lowering the link raises roll center and raising the link lowers the roll center.
Old 06-07-2013 | 07:45 AM
  #5951
bds81175's Avatar
Moderator
+1
bds81175 is offline
Old 06-07-2013 | 08:25 AM
  #5952
Wild Cherry's Avatar
Tech Legend
Use 1 shim on the CVA axle before installing into the hub & 1 shim under the axle pin ...
shim give the bearing a smooth seat to ride on .
Wild Cherry is offline
Old 06-07-2013 | 08:29 AM
  #5953
DanielC.'s Avatar
To clarify, the C hub tower change is usually done along with the use of a dremeled down U brace with 0-1mm of washers under the Ballstud.
Switching to the C hub tower without shaving the ubrace will lower your roll center.
Switching to the C hub tower and shaving the ubrace will raise your roll center.
You can achieve a similar feel with the A hub towers and running 0-1mm washers on an unshaved ubrace, but the feel will be slightly different.
DanielC. is online now
Old 06-07-2013 | 08:30 AM
  #5954
aeRayls's Avatar
For all you bandwagoners: AE just released the centerline esc shelf pn#7498.
aeRayls is offline
Old 06-07-2013 | 08:42 AM
  #5955
Tech Legend
A image of
