Team Associated B4.2 Thread >
Like Tree4Likes
Old 06-06-2013 | 10:24 AM
  #5926
I'm not 100% but I think the 25 Degree block is actually 0 degree change as the front kickup is 25 degrees. and 20 degree block is -5 and the 30degree block is +5
jdeadman is offline
Old 06-06-2013 | 10:26 AM
  #5927
Kellen Guthrie's Avatar
Originally Posted by Wild Cherry
going into the corner your right .
Out doors using 25 caster & rib tires is common and offen used ..
loose & dusty track , wide and sweeping turns ?
30 caster will only make the car more difficult to control.
Yeah i only run on high bite tracks normally. Never run out doors.
Kellen Guthrie is offline
Old 06-06-2013 | 10:41 AM
  #5928
yes running on high bite you will always notice a minor change more so than on loose outdoor conditions. i will test but most likely won't be able to feel anything, so its no big deal, just as easy to run as is. It still would be nice to know which is correct simply just for knowing, one of them has to be right....
Biz1974 is offline
Old 06-06-2013 | 01:08 PM
  #5929
Tradin Paint's Avatar
Originally Posted by hobbyten
I'm thinking if you read the directions you can do that manually but I could be wrong.
Yes, you can set the Tekin RS speed controls to blinky without the Hotwire however there is another setting called "locked spec mode" that can only be added or removed via a Hotwire.
Tradin Paint is offline
Old 06-06-2013 | 02:27 PM
  #5930
has anyone tried the new trinity killshot motors in one of these on a high bite clay track. track is coyote hobbies in victorville, took a small break and my motor is no longer legal with the new rules
dezertranger96 is offline
Old 06-06-2013 | 03:36 PM
  #5931
SCDriver's Avatar
Originally Posted by redskins
Can't wait to race it this Sunday.
Nice! I like the all white. Good luck Sunday!
The next race where I live isn't until the 22nd, damn I got to move out of this little town, somewhere they have more races!
SCDriver is offline
Old 06-06-2013 | 04:55 PM
  #5932
jbrooks39's Avatar
smoother & less aggressive steering....
Thanks for the response; makes sense based on what we used to do with our T3s indoor on carpet.
Does anyone ever go so far as to run the 20 degree caster blocks outdoors?
Thanks,
JB
jbrooks39 is offline
Old 06-06-2013 | 05:13 PM
  #5933
Nicholas Muelle's Avatar
What is the weight of the front shock tower, not the carbon one, just the regular one?
Nicholas Muelle is offline
  #5934
Skillz_B's Avatar
I like the all white also, my next body will be all white, and I just installed the Jconcepts Fin Turnbuckles and White RPM ballcups, all I need is a set of white dish wheels with tires. I am hoping the all white will make it easier for mr to track the buggy, I have lost movement in my neck, and my eyes arent what. They use to be.
Skillz_B is offline
Old 06-06-2013 | 05:30 PM
  #5935
Cain's Avatar
Tech Legend
Originally Posted by Biz1974
see now the below reports just opposite
http://users.telenet.be/elvo/
i know it's an internet source, however the hudy off-road and on-road manuals contradict each other as well with regard to the effects of off-power steering...which is right? Does anybody have Chad Knaus phone number...haha
one thing that is always consistent is the effects of straight line stability
Yeah, its funny how that can be sometimes.
For those curious, here is what the Hudy offroad guide says:
EFFECTS OF CASTER ADJUSTMENT
Less caster angle (more vertical)
• Decreases straight-line stability
• Increases off-power steering at corner entry
• Increases suspension efficiency
More caster angle (more inclined)
• Increases straight-line stability
• Decreases off-power steering at corner entry
• Makes the car more stable through bumpy track conditions
based on what I have seen actually running on loose outdoor conditions, pretty much performs as the hudy guide says above.
when I ran indoor foam touring car as an onroad comparison, it was quite common for us to go with more caster to calm the vehicles down so they didn't hook at corner entry.
But, as it is, its a change that can be easily tested.
Cain is offline
Old 06-06-2013 | 06:52 PM
  #5936
Wild Cherry's Avatar
Tech Legend
Traction is coming up at Trcr , a few have gone with stiffer springs(grey) to take advantage of the grip for more corner speed.
Not me...
Instead ditching the C hub for the A.
Just gave it a try , very nice...
Corner speed is up and car feels great
A hub rolls more , free's up the back end compared to the C
Wild Cherry is offline
Old 06-06-2013 | 07:29 PM
  #5937
Blitzrockey's Avatar
what hubs come stock on this car again the a b or c?
Blitzrockey is offline
Old 06-06-2013 | 07:56 PM
  #5938
Wildcat1971's Avatar
A
Wildcat1971 is offline
Old 06-06-2013 | 08:06 PM
  #5939
Originally Posted by Wildcat1971
A
Which ones would be the best to use on a low traction track? Thanks.
Old 06-06-2013 | 08:30 PM
  #5940
mkennedy's Avatar
A
mkennedy is offline
