Team Associated B4.2 Thread
#3917
#3919
I just put them in and run them. When they get gritty, I just replace. At $1 per bearing, it is really not worth the effort to remove the shields, clean them and relube/grease. I recently had a gritty bearing. And the LHS didnt have any in stock. So i pulled off the shield, cleaned the bearing and lubed it. After a couple runs it was gritty again. In my experience, once the bearing is gritty, just replace it. unless you can t replace it, like what happened to me.
#3921
No, it is NOT normal for the gear boxes to be tight or bound up after assembly. The "anal ones" will blow the grease out of the inner bearings before installing them...I used to do this myself...trying to ditch all that "analniss" though these days.
#3922
I think there is some mis information here
The A hub and C hub have the same hole pattern, difference is the C hub is 2 mm lower, at the ball stud mounting location, then the a, this is why you have to shave the rear brace 2 mm to get the links flat, unless you raise the inside ball studs with washers.
This is why avid makes the carbon piece that carries the and c in the same piece.
Common starting point with a c hub is 1mm washer under the inside ball stud
#3923
[QUOTE=gguertin145;12030935
Do you guys clean your bearings before installing in offroad or just run them the way they came?
Thanks![/QUOTE]
I clean my bearings , and check if bad . Can get much longer life if you do .
I have been using the same Avid bearings for almost a year now & they are smooth as new ...
Thanks![/QUOTE]
#3924
Daniel , yes does sound a bit confusing ..
Learn more about raising & lowering the roll center and it will make more sense ...
Raising the roll center will lower traction..
The C-Hub already has the roll center raise up , adding more spacers raises it even more making less grip .
The A-Hub will bring more grip as you raise the inside ball stud , feels a lot like using a longer link .
#3925
I will ignore you now ...TY
#3926
Isn't that conflicting? With shaved you're saying to raise ball stud to free up the rear and to free up the car with A-hub/not shaved you're saying the opposite. As long as your roll center isn't way off wouldn't raising the inner link free it up on corner entry/ lock in later regardless?
I would just start over. Empty the case wipe everything down and start over because I just built mine last night and its butter. But I am super careful when building, I take my time because it saves you time at the track.
Lol! Take that Jack!
#3928
The buggy felt good, but am going back to the traditional electronics layout. Inline setup looks dialed but is less consistent on the looser tracks. Will be messing with the machined pistons this weekend
Edit: his ignore list must be endless.
#3929
lol, I mounted my centerline high. And my body hit the caps on the esc, so I was like, screw that. And put it back to its normal spot. My buggy actually felt really good. We went to night racing so the track was more consistent and I could work on my line and less on fighting the car. Now if only I could see my car....... lol. I am trying a Flo paint job this week. I am also going to ask the RD if we can put white stripes on the top of some of the further jumps. I was just guessing where the jumps were, lol. But the car felt great. I was on the verge of selling it, but I think I will keep it. I like the way the car handles. I think I have just been fighting the track for the last 3 months.
#3930
With all of my experience lowering the inside ball stud frees the car up in the corners by letting it not lean as far since the roll center was raised.
I prefer what i am running which is A hubs (exotek atm) in the B hole and #1 hole on a un-shaved brace with 2mm spacing. I run on a medium and sometimes medium to high bite track and unless i do a inline electronic layout with the esc up high then i will try the c hubs, but for now i cant be more happier with the hartson/numan set-up with the K springs.
Edit: The only difference between Hartsons set-up and mine is i am running green JC tires, pressure point rear, barcode front and i am running the AE machined tapered pistons, 2x1.6 rear and 3x1.4 front with 32.5w all around, everything else is the same as far as i know, maybe a very slight battery placement difference.
4Likes
