Team Associated B4.2 Thread >
Like Tree4Likes
Old 03-21-2013 | 02:07 PM
  #3166
Wildcat1971's Avatar
did you look at the manual?
the gap between the ends should be 2mm. you can put 2x 1mm washers between and be done. set your endpoints also.
Wildcat1971 is offline
Old 03-21-2013 | 02:16 PM
  #3167
hey guys can you fill me in on the set screw talk with the rear hubs.
laceup is offline
Old 03-21-2013 | 02:19 PM
  #3168
check the first page of this tread or the first page of the b4.1wc thread.
Old 03-21-2013 | 02:28 PM
  #3169
davidbarton87's Avatar
If I am understand correctly you drill and tap thru the hub and 1/2 way INTOthe pin right? Just making sure I dont drill to much.
davidbarton87 is offline
Old 03-21-2013 | 02:31 PM
  #3170
i used full size ball ends cut down to RE-make the steering link because one of the ends stripped out. so now i need to know what the total length should be instead of the "gap".
Matt
mat3833 is offline
Old 03-21-2013 | 02:32 PM
  #3171
bds81175's Avatar
Moderator
You don't really need to do anything with the pin. Just drill and tap the hub. You are just trying to force the pin against a quadrant of the hole in the hub. Works like a charm. I've seen them with two set screws but really only one is needed.
bds81175 is offline
Old 03-21-2013 | 02:49 PM
  #3172
Gotcha I was figuring it was just like a set screw in there but the instructions say to drill into the pin, but I think that would probably weaken it quite a bit.
Old 03-21-2013 | 02:53 PM
  #3173
Matt
Do the full size ball ends fit the steering ball studs? I thought I remember them as being a bit smaller.
negatv1 is offline
Old 03-21-2013 | 03:02 PM
  #3174
they fit fine, and i solved the problem. the servo saver arm is kinda thick, so it hits the center support post before all the steering throw is used. so i just sanded down that side of the saver and now i have full throw in both directions.
got an Avid steering rack on the way anyways.
Matt
mat3833 is offline
Old 03-21-2013 | 03:39 PM
  #3175
Tradin Paint's Avatar
Check the manual? Why do that when you can come on here and ask the question and let someone else check the manual for you
Tradin Paint is offline
Old 03-21-2013 | 03:47 PM
  #3176
do you guys normally run short or long wheel base indoors?
laceup is offline
Old 03-21-2013 | 03:50 PM
  #3177
t0p_sh0tta's Avatar
Depends on the track. I spend 95% of my time trying to tame the rear end, so short.
t0p_sh0tta is offline
Old 03-21-2013 | 03:52 PM
  #3178
Wild Cherry's Avatar
Tech Legend
In the middle ....
Wild Cherry is offline
Old 03-21-2013 | 04:09 PM
  #3179
normally i would agree with this comment, even tho it is more or less directed at me. but in this case i checked the manual and the manual doesn't list an overall length. i posted a question so that i could get an answer, and i still need that answer so i can sort out the steering rack and be done with it.
Matt
mat3833 is offline
Old 03-21-2013 | 04:12 PM
  #3180
AE-Reedy
Matt
end to end 1"
Sean Cochran is offline
