Team Associated B4.2 Thread >
Like Tree4Likes
Old 02-10-2013 | 09:01 PM
  #1501
Just1More's Avatar
Agreed. What's the best front tire and front/rear foam setup for you? I'm partial to worn in AKA foams all around and gold barcodes up front.
Just1More is offline
Old 02-10-2013 | 09:25 PM
  #1502
YankeeFan123's Avatar
I'm running gold barcodes up front. I usually use stock rears trimmed slightly and stuffed in there but I didn't have any on me so I got some Bomb 1 from my buddy and it is a little stiff at first but gets softer over a few days at the track and I really am liking them so far. And I also really like the AKA foams in the rear
YankeeFan123 is offline
Old 02-11-2013 | 12:41 AM
  #1503
Arran_T's Avatar
Default Slipper clutch setup?
Hi All,
Firstly, sorry if this has been covered before but I couldn't find the answer i'm looking for with a reasonable search...
I've put my first racing buggy together (B4.2) & am pretty happy with the build for the most part. But... I'm all at sea with regard to the setup of the slipper. Is there a rule of thumb for setting it up?
BTW, i'm running a Hobbywing Xerun combo, 17.5T brushless motor (AU stock class) with 120A ESC.
Thanks in advance for any tips.
Arran_T is offline
Old 02-11-2013 | 02:45 AM
  #1504
OMG23RC's Avatar
This has all the info you will need:http://www.rctech.net/forum/electric...er-clutch.html
OMG23RC is offline
Old 02-11-2013 | 05:46 AM
  #1505
66Racer's Avatar
Originally Posted by GizmoTLR
I used to always break the bulk heads until i switch to the aluminum one. Now i only break the arms. I cant remember the last time i broke a shock tower or u-brace. Never broke a servo arm yet.
I'm going on 3 months with my kit and haven't broken a single bulk head.
66Racer is offline
Old 02-11-2013 | 06:07 AM
  #1506
Tradin Paint's Avatar
I don't think I ever broke a bulkhead. I did recently switch to the aluminum one just for the weight and looks. I can't see how these are breaking so often for others
Tradin Paint is offline
Old 02-11-2013 | 06:51 AM
  #1507
samuelsonmark71's Avatar
Everyone else have to trim the front tower so that the shock adjusters move or just space it out a bit more?
samuelsonmark71 is offline
Old 02-11-2013 | 06:53 AM
  #1508
t0p_sh0tta's Avatar
Couldn't just throw another .5mm shim under the upper shock mount?
t0p_sh0tta is offline
Old 02-11-2013 | 07:08 AM
  #1509
Wildcat1971's Avatar
I trimmed mine. The thing is, I trimmed both my front and rear to my liking. I figure they would break for sure. Well that has not happened and I have had some vicious tumbles. Just this past weekend, someone clipped me as I hit a double at full speed. I think my buggy bounced and flipped a good 20 feet and nothing broke (soft outdoor wet clay). So if you need to grind a little, I am sure it will be fine, just dont go crazy. Also, fo those of you using C hubs and still scraping up your shocks. Just mount the hubs on the backside and put 2mm washers under the stud. You wont ever rub and moving the link on the horizontal plane does not seem to affect handling at all. If you are using the A hubs and rubbing, look at the exotek rear hubs. The vertical ball stud positioning helps to move the link further away from the turnbuckle. I use Lunsford turnbuckles which are thicker than the AE ones, so a few shims are not cutting it for me. I tried .090 shims on the bottom, cut the tower and used the Carbon A towers and still rubbed slightly with the lunsfords.
Wildcat1971 is offline
Old 02-11-2013 | 10:19 AM
  #1510
Dork Missile's Avatar
Default new kit
did anyone get upper aluminum shock mounts that are tight? really tight? i was hoping it wasn't the shock caps...but it turns out its the shock mounts. I'm pretty sure i'm going plastic anyways. other than this small detail...kit is very smooth!
Dork Missile is offline
Old 02-11-2013 | 10:40 AM
  #1511
Jmuck69's Avatar
This seems to be a common issue but really a non-issue. It will break in or you can use a green pad (Scotchbrite) and twist the shock mounts in a folded over pad and this will help.
Jmuck69 is offline
Old 02-11-2013 | 10:45 AM
  #1512
This will work. I put the shock mount in a drill and spun it while holding some fine sandpaper to sand off some material (same idea as above)
I don't think I got much deeper than removing the anodization before it worked.
otter is offline
Old 02-11-2013 | 10:51 AM
  #1513
Tighter diff is less steering and more forward bite correct?
Old 02-11-2013 | 10:54 AM
  #1514
Jmuck69's Avatar
Yup! Acts like positraction as on a fullsize car but sacrifices straight line stabiltiy going through a washboard or bumpy section.
Jmuck69 is offline
Old 02-11-2013 | 11:01 AM
  #1515
I think mine is too loose. I am having issues accelerating out of the corners. The rear feels unstable. This week in the main the track lost traction and 1/3 up the straight, I was fish tailing if I tried to get more into the throttle. I have my diff set to 1/2 lift on the slipper setting, any tighter slipper and the diff will bark. So I might tighten it a little. I started running it really light with the v2 shocks to get more steering in the corners. But the BB shock have introduced a lot of steering themselves, so I might tighten her a little. I still dont have the consistence I did with the v2 shocks. Mostly because my rear seems loose. I tried a few different tires, but that is not really fixing it. I think I am diffing out a little come out of the corners or when the track is a little looser.
