Team Associated B4.2 Thread
#1352
I will stick to standard placement for now.
#1353
They do not allow for a C hub ball stud location, only A or B. The Yaiba aluminum hubs allow for all three.
http://www.tresrey-usa.com/yaiba-rac...num-rear-hubs/
AE has the right idea on hubs. Mount horizontally with plastic stand off that can be replaced cheap or with tough carbon fiber that isn't threaded so any broken ball studs can be replaced. Hubs like these are just asking to snap a ball stud off inside the hub where it cannot be extracted.
#1354
#1356
I remember running a gas truck that had verticle ball studs on the hub (think it was a Drake 2) and everything was solid on that truck except the ball studs. Seemed like every few months it was time to replace the hubs as the snapped ball stud required cutting into the aluminum hub to remove the screw.
I like AE's design much more.
#1357
maybe the need to use a ball stud that also has a hex bit opening on the other side. That way, if it breaks off, you could potentially get to the other side and thread it out easily?
thinking about it, if I used these kind of hubs, I probably would slot the end of each ballstud so I could at least try it with a flat head screwdriver for now.
#1359
#1360
Some how I stripped the lower hole in my Reedy Sonic motor.
Hit a bump hard and the back of the chassis under the motor slapped real hard.
Any way to fix this without getting a new motor, which I REALLY do NOT want to do!
Thanks,
-Venom
Thanks,
-Venom
#1361
Not sure , but maybe remove the can & rotate before you assemble so you can use the other motor screw holes ....
#1362
4Likes
