Team Associated B4.2 Thread >
Like Tree4Likes
Old 02-04-2013 | 08:25 AM
  #1201
turbo2cam's Avatar
I agree it's a "huge" amount...(maybe we are on the same page, maybe not) That's why I am having a really hard time believing the people that are saying their arms are twisting/flexing that much. I mean, the front arms have the same, maybe even less clearance...and IMO, the front arms have the capabilities of flexing even more...but nobodies complaining about that?
IDK, like I said, I'm running with it. If for some reason it becomes an issue...I'll move the shock tower forward, and space the shock away from the arm. That seems to be the most logical solution i've come across so far.
But as of yet, I personally, am having no issues. Too each their own.
turbo2cam is offline
  #1202
Jason Haas's Avatar
Originally Posted by micrors4guy
The only issue with thoes is in order to get the c hub position you will need to mill them down. The ball with no spacers =a holes with thoes.
run a short neck ball stud
Jason Haas is offline
Old 02-04-2013 | 08:28 AM
  #1203
vito's Avatar
are the big shock kit nice? and what springs to pick of just the stock one ? its a 4.1 kit sorry i think b4.2 guys run them wiil have good feed back in here
vito is offline
Old 02-04-2013 | 08:54 AM
  #1204
2canSAM's Avatar
R/C Tech Elite Member
The Big Bores are nice but since you are not racing, and just running up and down the street. I say they would be a waste of money. Since I am sure you will buy them anyway They do not come with any springs stock. I would say if running in the street to pick up both the Medium kits for front and rear. If you will be moving onto the track go for the Soft kits front and rear.
2canSAM is offline
Old 02-04-2013 | 08:56 AM
  #1205
Wildcat1971's Avatar
I run A Hubs here in AZ, but yeah. There are new red hubs out that have a lower C position.
http://www.buggy-sport.info/index.ph...-associated-b4
Wildcat1971 is offline
Old 02-04-2013 | 08:57 AM
  #1206
vito's Avatar
i found a track just an bit north of me
vito is offline
Old 02-04-2013 | 08:58 AM
  #1207
Venom1836's Avatar
Could I get a part # for B44 arms, I want to make sure I am getting the right ones.
Thanks,
-Venom
Venom1836 is offline
Old 02-04-2013 | 09:04 AM
  #1208
Matt Trimmings's Avatar
Thanks,
-Venom
http://lmgtfy.com/?q=B44+rear+arms+part+number
Matt Trimmings is offline
Old 02-04-2013 | 09:06 AM
  #1209
Drewsrcs's Avatar
Drewsrcs is offline
Old 02-04-2013 | 09:07 AM
  #1210
Originally Posted by Matt Trimmings
lol at "Let me google this for you" lol.
Old 02-04-2013 | 09:10 AM
  #1211
Tradin Paint's Avatar
The ones that have the same measurements as the C hubs are nice. You can then just add washers to get them up to the A level
Tradin Paint is offline
Old 02-04-2013 | 09:12 AM
  #1212
The confusing part is, where is says you can add the provided spacers to be the same as the C height. That implies the hub is actually lower than the C unless you add spacers. But I know things are lost in translation sometimes from japan/china.
"It has same position with Team Associated C-Type REAR HUB CARRIER when using included spacers 2pcs for each side."
Old 02-04-2013 | 10:33 AM
  #1213
All this talk about turn buckle rubbing on the shock. Mine rubs and I built it to exact kit setup. I honestly don't see how it couldn't rub unless you run longest wheelbase.
Somebody should snap a pic if you have built it with middle wheelbase and you claim it does not rub. I would like to see what is different with your car vs my car.
chevmaro is offline
Old 02-04-2013 | 10:34 AM
  #1214
kyle3333's Avatar
What is a good Futaba servo to use for the B4 or for 1/10th off-road in general. I have always used the XP DS1015 servos and never bothered to experiment with anything else.
kyle3333 is offline
Old 02-04-2013 | 10:44 AM
  #1215
Wild Cherry's Avatar
Tech Legend
If you use 2 x .030 spacers on the bottom
shock eyelet it will not rub .
all you need to do , Ae tells you too as well ...
Wild Cherry is offline
